Click for Mulder Click for YF Listing Service Click for Abeking Click for JetForums Click for Ocean Alexander
Painting Inside of Hull on Steel Sailboat
Discussion in 'Technical Discussion' started by JonMcg, Nov 9, 2015.
  1. JonMcg
    JonMcg New Member
    I've recently bought a 35' steel ketch, it's a self build. The original builder blasted and epoxy coated the interior, it's in very good condition, just a few bits of rust at some seams and down where concrete was poured into the bilge. We'd like to cover the interior paint in white -- I've two questions.
    1. What type of paint (system) makes sense to overcoat the two part epoxy that was initially sprayed on? (and should i use a different paint for the small bits of rust and then overcoat everything, or is there a product that would work to just do another whole layer.
    2. The ballast/bilge is rough concrete with some steel and some random lead chunks laying about, i'm wondering about sealing the concrete and overpainting with something (like floorpaint?) and do i need to worry about rust in the area the concrete is poured.
    any thoughts would be appreciated. Will obviously scrap back rust as much as possible etc.
    Why do you have concrete in your bilge????
  3. JonMcg
    JonMcg New Member
    It's the poorman's lead. It's not a totally unheard of practice here in Europe, can be chipped out latter at some point if needs be. It was just an issue of not being able to afford the lead when the thing was being built.. any idea on the paint?
    No, you have to figure out what you currently have and see what you have to do to paint over it. You should sand down, prime, and then coat any area's where rust is present. I'm not familiar with the paint/epoxy products in Europe.
  5. JonMcg
    JonMcg New Member
    I have a two part epoxy on mild steel. I'll get the rust sanded etc away from areas so i'll be putting a primer ontop of another epoxy and to cover some mild steel where the epoxy has chipped. I'm thinking interprotect two part epoxy paint. any thoughts?
  6. dennismc
    dennismc Senior Member
    Vancouver BC
    You need to keep using 2 part on top of two part, you could use one part but then that's what you have to use from then on..
    be sure the primer is also 2 part and you need to treat the steel before any priming or waste of time.
  7. JonMcg
    JonMcg New Member
    Great Dennis that was what i was trying to figure out ( what can you cover 2 part with)
    When you say treat the the steel do you mean an etch product? or something beyond sand scrap all the rust off, acetone wipe everything and prime.. i guess what would you do with the bits that are damaged on the hull.
  8. K1W1
    Remove any loose stuff and treat the remainder with OSPHO or similar then begin your paint system
  9. Capt J
    I agree, Ospho is good stuff and will stop the rusting.
  10. dennismc
    Vancouver BC
    If you are going to repaint with 2 part, be sure the primer is compatible with the Osho surfacing on the steel.
  11. marcbeaudry
    marcbeaudry New Member
    lake ontario
    Hello ,
    i'm hearing rumblings and mumbling from steel hull folk about the viability of painting bilges while the boat is still in the water. The claims being made are that painting below the water line shouldnt be tried unless the boat is on the hard as the difference in temperature will prevent the paint from sticking ( no matter what is used)
    has anyone got experience of comments on this either way?
    thanks
    marc
  12. Scallywag
    Scallywag Member
    Islamorada FL
    Makes sense if you are up there in cold water since epoxy is exothermic. Anything below 50 degrees is a no-go for most epoxies. The hardener won't "kick" and when it does it won't fully harden. I'm not a cold water guy, but I'd heed the rumblings and mumblings.
    Example: http://www.westsystem.com/ss/cold-temperature-bonding/
  13. PacBlue
    PacBlue Senior Member
    Dana Point, Ca
    When concrete ballast gets wet, the lime in the concrete reacts negatively with the steel and will corrode it from the inside. Big problem as you can not see it. Have to ultrasonically gauge the hull in the ballast area if you have any questions that the concrete's integrity is in question. Have to be sure that the concrete ballast is stone dry, no pun intended.
    A while ago, I recall seeing an epoxy product called Red Hand used to prime steel surfaces / welds in the bilges prior to painting: I think it has been renamed since to Intergard-822.
    http://www.international-marine.com/products/info/intergard-822.aspx
  14. marcbeaudry
    lake ontario
    right - but if a person waits for warmer weather/water... up closer to the operating temp of the epoxy (entirely possible late August) i would expect that a 2pack paint would kick even if the ambient temp is much higher than the water temperature.
    or is that an incorrect assumption?
    marc
  15. RT46
    RT46 Senior Member
    just curious, isn't rebar encapsulated in concrete a common construction technique?
    what prevents the rebar from corroding and weakening the structure?
  16. K1W1
    You probably can't see it because you don't have years to wait for anything you can see.
    http://www.cement.org/docs/default-...causes-of-concrete-deterioration.pdf?sfvrsn=4
    "Concrete and the Passivating Layer:
    Although steel’s natural tendency is to undergo corrosion reactions, the alkaline environment of concrete (pH of 12 to 13) provides steel with corrosion protection. At the high pH, a thin oxide layer forms on the steel and prevents metal atoms from dissolving. This passive film does not actually stop corrosion; it reduces the corrosion rate to an insignificant level. For steel in concrete, the passive corrosion rate is typically 0.1 μm per year. Without the passive film, the steel would corrode at rates at least
    1,000 times higher (ACI 222 2001)."
    It is common practice to use concrete for fixed ballast. Coal tar epoxy is a better coating for the hull area where the concrete is poured than the epoxy paint yachties use because it doesn't chip or crack. Cement coating of potable water tanks is also used to counter acidity and prevent the steel from rusting.
  17. PacBlue
    Dana Point, Ca
    Keeping rebar away from an external water or electrical source is what makes it safe as a concrete reinforcement for structural applications. In the 90's I was taking some night classes at UC Irvine, and they had an entire 7 story, brand new building condemned before it opened, as the rebar was exposed to the environment, corroded and then crumbled the adjacent concrete. Lessen learned for the county, at a cots of millions. Similar episodes have happened in CA for new bridge construction, failures before they even opened, cheap contractors with unskilled labor or willing to take short cuts, with poor government inspection / oversight.
    For concrete ballast, keep it 100% dry / sealed. Not much else to say about.
    Ferro-cement boats disintegrated from the inside out due to their (chicken) wire reinforcements being exposed to seawater / and stray currents. I am sure this forum has already addressed that topic.
  18. PacBlue
    Dana Point, Ca
    Yes, concrete is a fine ballast material when used correctly. It requires the right coating / sealant of the metal hull as well as eliminating prolonged exposure to bilge gunk. If exposed to a seawater source it will create the reaction I stated over time. How fast will depend on many variables.
    If you are unsure of how the concrete is put in place, better to resolve the issue. OP did not state how old / who built the vessel.
  19. Beau
    Beau Senior Member
    Beaufort, NC
    My son tells me that in concrete poured buildings the re bar is very often epoxy coated particularly for areas that will be prone to dampness.
  20. Capt J
    They have to re-do the entire concrete structure. In area's where salt water/air isn't present it doesn't seem to effect the rebar/concrete combo. But here in South Florida removing and putting new concrete balconies on all of the older ocean front condo's has become big business because they haven't been able to pass structural otherwise because the rebar has rotted inside the concrete. I would think this process would be sped up quite a bit with a steel boat and concrete in the bilge as well as salt water. The Lyme in the concrete (needed to cure it) rots steel and wood too.
