Click for Northern Lights Click for Westport Click for Delta Click for Ocean Alexander Click for YF Listing Service
Onboard water tank issue
Discussion in 'Luhrs Yacht' started by Rich Plukas, May 10, 2020.
  1. Rich Plukas
    Rich Plukas New Member
    Rochester, NY
    1999 Luhrs 360. When I am on the boat and have my city water hooked up it keeps filling my water tanks. I hate running that heavy. I replaced the water intake and pressure regulator about 2 years ago could that be failing already and be the cause of the tanks filling?
    Saf66 likes this.
  2. Pascal
    What kind of pump? If a commonly used diaphragm pump then water should not back flow to the tank. Other pumps may allow water to flow back in that case a check valve at the pump inlet or outlet should solve the problem
    personally I never hook up to dock water in case of a plumbing failure and to keep the tank fresh
  3. chesapeake46
    chesapeake46 Senior Member
    I've got a regulator and check valves between the tanks and the dock side inlet. Maybe your check valve has failed btwn the inlet and tanks.
    The house pump cant push water out the inlet and the dockside can't push water into the tanks.
  4. d_meister
    d_meister Senior Member
    La Conner, WA.
    Do the fresh water tanks overflow? It would seem that if there is backflow through the tank outlet and pump circuit, there would be water flowing out of the vents at some point. Also, if there is an issue where the pressurized house system bleeds back into the tank, there should be other symptoms like excessive pump cycling when disconnected from shore water.
    Otherwise, there could be a tank fill plumbing circuit that has a full shut-off. If that is the case, it could probably be shut off with a valve to prevent filling the tank.
  5. Rich Plukas
    Rochester, NY
    Thanks, even though regulator is relatively new that appears to be the only thing between the incoming water and the tanks- I'll replace that again.
  6. Rich Plukas
    Rochester, NY
    Thank you for the info. I ONLY run water from the dock when I'm on the boat- but like the fresher water for washing and showers.
  7. rtrafford
    rtrafford Senior Member
    Vero Beach
    If you're going to replace it, why not consider adding a ball valve to the plumbing for the certain ability of shutting off access to your tanks??
  8. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    What he said...check check one two..check the check valve. It's probably an in-line plastic unit.
  9. cleanslate
    Cherry Hill, NJ
    I would say there is an in-line check valve somewhere in the line . Could be near a Tee that splits the incoming water to go to the boats system and by pass the water tank. Probably in the bilge near the 12 volt water pump and tank.
  10. Pascal
    Again, what kind of pump? If a diaphragm pump, they have built in check valves. If one of them has debris keeping it open, you may not notice the pressure loss but it will allow water to flow back
