Click for Delta Click for Glendinning Click for Nordhavn Click for Westport Click for Burger
Onan Mdl4 Generator
Discussion in 'Generators' started by Lunderic, Jul 15, 2025 at 10:11 AM.
  1. Lunderic
    Lunderic Member
    Oceanside, NY
    My otherwise perfectly running generator had the rear main oil seal fail. My mechanic can't source the parts and doesn't want to proceed. Any suggestions? I was thinking of removing and just measuring and order from Grainger or other. Does anyone know of a source for obsolete Cummins/Onan parts? Cummins stated I need to replace the generator. I will eventually replace but just trying to finish out season if possible. Thanks for any suggestions!
    Any numbers still readable on the old seal?
  3. Lunderic
    Lunderic Member
    Oceanside, NY
    I didn't take it out yet. I'm a little tight on time so I hired mechanic but now he doesn't want to continue without being able to source parts.
    My notes show 509-0203 as the original OhNo rear seal part number (spec A).
    That includes a wear sleeve.
    Sadly, these engines are way past end of life and parts are near non-existing in North America.
    The last time I ordered MDL* parts, they came in from South America.
    Verify this part number, call your Cummins rep back up and ask for a world wide search.
    Maybe Cummins can offer the original vendors part number.
    I do understand why your tech is in no hurry to jump in there.
    It is a shame, when running, they are darn good engines but every time I work on one, it turns into a Pandora's Box. Splitting yours for a rear seal may turn into an ugly ordeal for you and your tech also.
    How bad is the leak? Will it last till you get home or end of season?
    Maybe some snake oil or thicker straight weight oil.
  5. Lunderic
    Lunderic Member
    Oceanside, NY
    It's leaking bad... after running for 10 minutes it leaks probably a pint. I can't run it as is.
    Ouch.
    No backup gen-set?
    Leaks in a tray, with a drain port?
    Have you been gen-set shopping lately?
    Where is your ship?
    You probably have an ole Hatt, what model ship?
  7. Lunderic
    Lunderic Member
    Oceanside, NY
    The boat is on Long Island. No backup Gen-set. She's a 93 53' Viking. It does leak into the tray but no drain port. I did start shopping, but I would like to get it going to at least get through the season.
  8. SplashFl
    SplashFl Senior Member
    S. Florida _ Bertram 46
    Previous boat had 8kw Onan. Turned out to be same Kubota motor as in Phasor Generator and the local dealership stocked parts priced way below Onan's.
  9. Capt Ralph
    These OhNo's had some nice at the time, Cummins engines.
    The MDL3,4 & 6 just never took off like the Kubota, Yanmar, Shibaura, Mitsubishi & Isuzu. Interchangeable parts was a great idea but I figure Cummins was just late to the party.
    Other than in gen-sets, I don't know of them anyplace else.
    Now that Cummins & OhNo are in bed with other, nobody else using that engine line, I fear there is no place else to shop for parts other than Cummins/OhNo.
  10. Capt Ralph
    By the way, That Kubota D1105 used in your previous 8kw OhNo is the same engine model I'm using for my #2 gen-set. Over 4000 hours and was running perfect;
    One of the intake valves stuck open during our vacation.
    It was much cheaper to purchase a whole new head thru Amazon than have my head serviced.
    My 20 year old, 5000+ hour #1 gen-set uses an Isuzu 4LE1. Since new, the only service was valve lash adjustment. I noticed Isuzu parts in Amazon also.
