Click for Ocean Alexander Click for Glendinning Click for Abeking Click for YF Listing Service Click for YF Listing Service
Onan MDKAW
Discussion in 'Engines' started by John Wilansky, Mar 16, 2020.
  1. John Wilansky
    John Wilansky New Member
    Melbourne Fl
    I have an Onan MDKAW in my Meridian 459...It can run for hours (varies) and suddenly shut down. It does restart...Anyone have any thoughts on this?
  2. rtrafford
    rtrafford Senior Member
    Vero Beach
    I've heard of false-overfilled issues with Onan genny's oil level. The suggested remedy as I understand was to run with the oil below full, above the add-line, but somewhat below full. Maybe in the lower half of that range. Seems like an easy thing to try...
  3. John Wilansky
    Melbourne Fl
    Thanks, I'll give it a try
  4. rtrafford
    Vero Beach
    I think I heard about this Onan issue from an RV guy. Said it was happening for a while, and seemed to be consistent with oil addition to his unit. The high oil level is a component of the unit's safety systems, and there is some question about the accuracy of the dipstick or something like that. Not sure if it's the same unit you've got, but it's what I've been told...
  5. John Wilansky
    Melbourne Fl
    Thanks for the info
  6. mapism
    mapism Senior Member
    Sardinia
    I experienced something similar on an ONAN genset, though I can't remember the exact model.
    And it took a while to find out that it was just an unstable contact on the shutoff solenoid.
    I can't grant you it's the same issue of course, but I wish you it is, because it only takes one minute to fix it, by tightening the contact.
    Thinking to check it was the only tricky part!
  7. John Wilansky
    Melbourne Fl
    Thanks nuch! I'll check it
  8. mapism
    Sardinia
    My pleasure. Keep us updated on your findings!
  9. Capt J
    How many hours on the unit? I've had this happen on a unit with a lot of hours and heat exchanger never cleaned and with a medium load it would run fine, then another a/c would kick on and it would hit the overheat safety switch and shut down.
  10. Pascal
    Yeah but it wouldn’t restart right away and you d hear the exhaust note and see some steam. But it s possible
    another possible cause is a flaky sensor. I always carry a full set of oil pressure, coolant temp and water flow sensora
  11. Capt J
    The one I dealt with didn't steam......it was a pretty good run from the engine to the exhaust so maybe the steam disappated. After I had the heat exchanger cleaned, 3x the water flow came out of the exhaust. Owner had had the boat 17 years and it was so gradual he never noticed that's all it was pumping towards the end.
  12. Capt Ralph
    Pascal and I have both been plagued by faulty senders.
    With a cheap I R gun, you can Trouble shoot the whole system.
