Click for Delta Click for Westport Click for Cross Click for Burger Click for Perko
Onan Drip Pan Replacement
Discussion in 'Generators' started by crackerD, Dec 30, 2020.
  1. crackerD
    crackerD Member
    Clearwater FL
    I've got an 11.5KW...drip pan is rusted beyond repair. How big of PITA/$$$ is replacing the pan?
    Drain the oil, unbolt it and roll it over on its side, replace the pan.
    The pan is simple.
    The difficulty and labor cost will be area you have to work in.
    You may have to pull the whole gen-set out of the boat.
    If you go that far, consider re-installing a new set.
  3. BRyachts
    BRyachts Member
    Ft Lauderdale
    I think there may be a terminology misunderstanding here. I think the OP is referring to the "drip pan" under the entire gen-set frame, and the responder is referring the the engines "oil pan".
    Ah, I understand your comment. I was not in tune with the OP.
    Drip pan replacement will also be labor intensive and subject to room available.
    You would be amazed, OhNo may still stock a new pan / tray. If not a good meal shop can repair or build a new one.
    Sound shields and covers off,
    Bonding straps from the block to the tray off,
    Any strain reliefs off,
    Tray un-bolted from the deck,
    Motor mounts un-bolted,
    Jack up or from overhead, raise the engine,
    Slide out old tray/ Slide in new tray.
    Reassemble in reverse order.
    With no idea what boat it's in,
    No gen-set model number,
    No pictures of gen-set,
    As anybody else can type the same generic R&R plan as I did,
    Nobody can offer real $$s.
    Agree, it's too difficult to estimate cost without boat/pictures etc. But It's a pain in the ass of a job even with good access. Sometimes you can get away with jacking it up with bottle jacks and blocking it to get the pan out from underneath, but overhead lifting is usually the preferred route.
  6. NYCAP123
    Is there a reason the OP couldn't just slide a slightly smaller pan inside the old or even just float resin into the pan to seal it?
  7. crackerD
    crackerD Member
    Clearwater FL
    The boat is a 56C Viking. 2 generators, one each aft of main engines. I'll try and get some pics.
  8. rtrafford
    rtrafford Senior Member
    Vero Beach
    Or a come along or ratchet winch supported overhead from structure, either permanent structure or temp. Have a fab shop build a stainless pan, and upgrade the engine mounds upon reinstall.
  9. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    The thing should only weigh like 400 lbs or so.Why not just make a simple lifting jig out of some wood 4x4’s or similar? Lift it up, remove and replace. If you don’t have enough clearance above, slide some steel angle iron pieces under the block and use a porta-power with some pancake jack heads. Really shouldn’t be that hard. If you don’t feel comfortable undertaking this should be a routine project for just about any service provider.
  10. Capt Ralph
    I wondered about this last night.
    Is this the early Cummins-OhNo's?
    Cummins MD3 bolted to an old alternator end?
    There was so much heavy sheet metal around them to sink a dink.
    Removing all that sheet metal will be a job.
    There are not many spare parts left for these motors and hard to imaging any trays left.
    Making a new pan and attaching all that sheet metal back on will be also a challenge.
    What is your tray failure?
    Repairable in place?
    You find any model numbers yet?
  11. crackerD
    crackerD Member
    Clearwater FL
    Here's the model number
    MDKAW-5691073
    There wasn't a failure. More of a cosmetic move. Metal brushing, treating with ospho, and painting isn't an option. Tray is corroded beyond repair.
  12. Capt Ralph
    The Cummins/OhNo web site has changed. No more free manuals.
    I did find this PDF in my archives.
    Later Kubota with OhNo original styled round alternator.
    around 2004 model.
    These trays may still be available.
    Still lots of sheet metal attaching to the tray.
    Pull yours and have them blasted and repaired would be my first idea to offer.
    Heavy rascal. Starts @ 640lbs.
    How many hours on yours? You may consider shopping for new sets.
    Close to R&R expenses either way.
  13. crackerD
    crackerD Member
    Clearwater FL
    Thanks Capt Ralph. This is a back up gen (11.5kw) only 550 hrs. Second hand boat. Main gen is 21.5kw. No idea why the old owner didn't just do two 21.5 as they are the same size physically.
  14. NYCAP123
    You don't want to underload gens. So when things like air conditioning aren't used the smaller gen would be the one to use.
  15. Capt Ralph
    Well, I'm still thinking.
    It's a labor intensive job that will be hard to quote before hand by anybody.
    Is it a glass or wood deck under the tray?
    Tell me about your ospho try.
    All real clean before it's application?
    Real metal primer used soon after?
    Real quality paint over the metal primer?
    Final paint left to dry several days before it got wet?
    Is there sitting water often in the tray?
    How is the tray under the 21.5?
    Hours on the 21.5?
    Or, do you want a matching 21.5?
  16. Capt J
    If it's an older generator, I would just put a new generator.....Either ONAN or Northern Lights and be done with it, before I go through all that.
  17. Pascal
    It seems to me that having a larger and a smaller gen was popular a while back. Some called that a night gen. All the boats built since the 90s that I ve run Seem to have equal sized gens.
  18. Capt J
    The newer gens with computer controlling can handle the lighter loads with no issues. Every yacht I've run that had a smaller gen, it NEVER got used, because it was never useful. Always tripping the breaker when someone turned the microwave on or a burner or two, resulting in starting the bigger gen and switching over, rather than slowing down or taking a trip down to the engine room to reset the breaker. Perhaps in the PNW it might be useful. But generally you have enough loads on the newer yachts with stuff like zero speed stabilizers at night as well as HVAC, water heater......water maker, etc. Plus having 2 equal gens means being able to carry more useful spare parts.
  19. Capt Ralph
    Some boats can work with a smaller gen-set at night, some can not.
    We have a 30kw, 9kw gen-sets and auto 4kw inverter.
    Did not like running the big set un-loaded. We put the 9KW in.
    Always had some inverter available.
    No need for a gen-set when the weather is pleasant on our trips.
    Sorry to get off topic. I did open up the distraction in my last line in post #15.
  20. DOCKMASTER
    Ketchikan, Alaska
    I really like my set up with a 20k and 9k . The 9k covers my needs 90+ % of the time. I only need the 20k when if using the dryer, watermaker or lots of stuff at once. But, of course, I’m not using A/C.
