Click for YF Listing Service Click for Northern Lights Click for Delta Click for Ocean Alexander Click for Nordhavn
Ocean 48 SS 1999 LEAK
Discussion in 'Ocean Yacht' started by skufful, Aug 11, 2012.
  1. skufful
    skufful New Member
    Beaufort, SC
    I have a 48 SS that leaks in the foward stateroom on the starboard side at the foot of the bed. I have re sealed the bow rail, rub rail, and the window. Anybody have any clues?? Is there any way for water to intrude from above other than the hatches. I do not think it is the hatch as the starboard hatch is in the head, and the forward hatch is to far forward and I would think I would see water on the headliner.
    Help
  2. AMG
    Start with checking if it is sea water or rain water...
  3. skufful
    skufful New Member
    Beaufort, SC
    Rain water - only when it rains
  4. AMG
    OK, then you can try with a water hose, spraying (carefully) bit by bit with somebody checking inside.
  5. skufful
    skufful New Member
    Beaufort, SC
    Thank you for your response.
    Unfortunately, there is no access to see where the source is unless I start doing some serious de-construction!.
  6. MadDoc
    MadDoc New Member
    Cape Canaveral
    the only leak I had was in the starboard stateroom and it was from screws popped from the rubrail. I had to take down the wall board to find that was the source. Good luck!
  7. MadDoc
    MadDoc New Member
    Cape Canaveral
    forward stateroom? check the anchor locker...
    I've seen many deck hatches leak and run down on the inside of the vinyl headliner and show no source of leak until where it came out of the vinyl, but remember water leaks downhill. Also check your air conditioner drain pan and make sure the drain is not blocked.......
  9. MadDoc
    MadDoc New Member
    Cape Canaveral
    yes, you do have to pull off the headliner/wall boards
