Click for Abeking Click for Northern Lights Click for Mulder Click for Glendinning Click for Perko
Ocean 40 leaking thru hull forward bilge
Discussion in 'Ocean Yacht' started by Rainmaker$, Feb 26, 2024.
  1. Rainmaker$
    Rainmaker$ New Member
    North Caolina
    Need help and info…. I have a through hull fitting that has been seeping water into the forward bilge for some time now.
    The pump pumps it out every day but I was wondering if the seeping has made the hull/ keel area saturated and adding weight to the boat .?
  2. Pascal
    How is the hull built? Cored?if so Balsa or foam?
    If solid glass or foam cored you don’t have much to worry about in the near term but if the hull is balsa cored, the balsa will rot and you will get delamination. The longer you wait the worst it will be.
  3. Rainmaker$
    North Caolina
    I believe all Oceans in 2004 were solid fiberglass, it has had this slow leak since I purchased the boat over two years ago and I’ve had the boat pulled and blocked …. There has been no delamination . I also have a diver that scrubs the bottom every month and there has never been an issue .
    I confirmed this morning that the through hull fittings are staying dry after I pump water out so now I’m not sure where it’s coming from !
    It’s in the forward bilge close to the head but I tested the water and it’s definitely salt water .
  4. 45SS
    45SS Member
    New Jersey
    Is your head fresh water or salt? Any other through hulls in the boat that would allow a leak to run to that area of the bilge?
  5. Rainmaker$
    North Caolina
    Head is fresh water , have checked all thru hulls and all are dry… going to check all hose fittings in that bilge as well as the shower drain line today but seriously doubt that’s the cause of the slow leak.
    My biggest concern was if the bottom of the boat/ keel was holding water .. thus adding weight but based on research the hull of the 40 ft ocean is solid fiberglass .
  6. alvareza
    alvareza Senior Member
    Scituate MA
    I believe all Oceans drain forward when at rest. The water could be leaking in from the engine room or from fish boxes to the bilge then forward.
  7. Rainmaker$
    North Caolina
    Need some help on my 2004 Ocean Yachts 40 SS
    boat has the original Cat 3126 engines and gear boxes …. Can’t read info on gear box plates and I need to know the gear ratios…. ???
    thanks in advance to anyone that can help !!
  8. Capt Ralph
    Pick up a cheap hand-held photo tach. Always good to have anytime already.
    In gear, read the crank (at the harmonic balancer) and shaft (at the flange coupler).
    Some math and you will have it.
    Bet a beer near 2.5;1
  9. Rainmaker$
    North Caolina
    Thanks Captain! That’s a bit beyond my skill set … but I’ll give it a try …. Unless someone knows for sure !
  10. boatpoor
    boatpoor Active Member
    Also called a strobe light.
  11. Oceanyachts40
    Oceanyachts40 New Member
    Chesapeake md
  12. Oceanyachts40
    Chesapeake md
    I have a 1999 40 found water from anchor safety line water running down it and into bilge .
