Click for Westport Click for Mulder Click for Perko Click for Northern Lights Click for YF Listing Service
Now this is a Tender!
Discussion in 'General Yachting Discussion' started by NEO56, Sep 6, 2014.
  1. NEO56
    NEO56 Member
    Miami
    In my other life, I developed a Variable Geometry Venturi for jet pumps that worked much like the afterburner on a modern fighter jet, sans thrust vectoring. Many months of testing yielded positive gains in a surfacing environment and a prototype vehicle was delivered to the Special Warfare Combatant Craft division where a crewman promptly used 100 feet of beach as a high speed brake, packing the pump full of sand, taking our aperture out of the picture, sorta speak. A year later, with a little influence from previous research by Kelly Johnson on the SR-71 Blackbird project, I designed a VGV with no moving parts.
    Moral of the story: No amount of in-house testing can prepare a product for real world use. When it comes to boats, KISS rules, especially in a salt-water environment. The Iguana has over 700 parts!
  3. NEO56
    NEO56 Member
    Miami
    I agree with you Carl, but you know the old P.T. Barnum saying "there's a sucker born every minute!":D
  4. MountainGuy
    MountainGuy Member
    Austria
    Its a toy, its cool, I wouldn't want it and I do not like what it does to the beaches...
    Would I be wrong to say its a "What the hell, as long as it's cool I don't care about anything" toy?
  5. CaptPKilbride
    CaptPKilbride Senior Member
    On the water
    This venturi pump piqued my interest.
    Without thrust vectoring, would it's application be for a center booster waterjet in a triple waterjet application? Would you be able to use the "afterburner" as a sort of "variable pitch" function to act as an overdrive at higher speeds when the resistance curve has flattened out?
  6. K1W1
  7. Marmot
    It would be easy to locate and convert to scrap though.
    It kind of negates what submarines are supposed to be about doncha think?
  8. YachtForums
    It could be, but this pump used a diverter for directional thrust aft of the venturi.
    It's basically the same concept, although our pump already had a variable pitch impellor and stator vanes. Because the pump was operating in a highly aerated surfacing environment, as speed increased the amount of water available to be converted to thrust was reduced, therefore a variable geometry venturi was developed to reduce the diameter of expulsion orifice. This worked in conjunction with an intake gullet bladder that expanded to increase negative pressure (vacuum) at the intake.
  9. YachtForums
    You are right Marmot. Cavitation isn't your friend when cloaked, but in fact - and contrary to most boater's beliefs - cavitation IS our friend, especially when you add the 'super' prefix. Lots of research on this at Carderock's LCC years ago. I may have been there. Juliet Marine is just getting up to speed, but little do they know, there are lots of knots left...
    Juliet Marine's Ghost Boat
  10. chesapeake46
    chesapeake46 Senior Member
    Do today's torpedoes go as fast as 3600 mph ?
    Could they be outrun ?
  11. YachtForums
    Weapons aren't a sector I worked in, nor am I privy to, but super-cavitating torpedoes have achieved speeds in excess of 200 mph.
  12. chesapeake46
    So, in theory, if a super cavitating, 3600 mph submarine launches a super cavitating torpedoe, then he better slow down a bit.
    Sorry, it reminds me of the comedian asking if your car goes the speed of light and you turn your headlamps on, what happens.
  13. lovinlifenc
    lovinlifenc Member
    Wilmington NC
    I agree with Carl. 700 moving parts is too many, especially for something that will be in constant contact with water or whatever you are tied to.
    I like this solution better
  14. Pascal
    I saw one if those dinghies with training wheels in action at Staniel cay earlier this year, clearly the owner had mobility issues had to be brought on dry land.
    Looked cool but like so many cool things it looked unpractical. Took forever to transition, slow and cumbersome on land.
    Did attract attention though....
  15. ArcanisX
    ArcanisX Senior Member
    Tel Aviv.
    It seems inventors gave up on a car/plane hybrids for a while to do a bit of car/boat ones.
    Because a combination of fresh milk and pickled tomatoes is supposed to work out entirely different then one of fresh milk and pickled cucumbers :p
  16. Capt J
    They tried that in the 1960's with the amphicar and it doesn't look like these are going to be anymore successful......
  17. ArcanisX
    Tel Aviv.
    Meh I hate them making me feel so green. I only tried dairy and pickle in late 90's...
    But then again, most genius ideas looked awful at some point. I do hope one day we get at a form of "universal locomotion" which is gonna make the difference between a car, a ship, a hover and probably even a full-altitude plane moot.
    And to get there we need the research. Funded by beta-testers. ;) So in a sense, for the greater good, we should probably advertise this frankenthing.
  18. Old Phart
    Old Phart Senior Member
    I dunno
  19. Capt J
