Click for Abeking Click for Abeking Click for Cross Click for Westport Click for Northern Lights
Night Vision Navigation
Discussion in 'Technical Discussion' started by brian eiland, Jun 9, 2011.
  1. brian eiland
    brian eiland Senior Member
    St Augustine, Fl and Thailand
    I recently read a promotional piece on these night vision equipments. Has anyone had experience with these equipments, or competitive products?
    Current Corporation's night vision cameras allow users to navigate adverse weather conditions, avoid collisions with objects at sea, detect threats like pirates and better conduct search and rescue operations in the dark of night.
    ...the company’s latest system, the Night Navigator SOSTM. “It’s a four-sensor actively synchronized system that combines to produce one Night Navigator SOS image. The result is unprecedented detail and clarity that has the capability to penetrate weather, such as rain, snow, smog and fog”.
    Night visibility in severe weather conditions can be very challenging. It's claimed that a vessel equipped with the Current Corporation’s Night Navigator system can detect a 10-meter boat or the spout of a whale at 2000 meters.
    I have a good amount of night cruising with the FLIR system. There is no way you can see anywhere near 2000 meters with it. It's good to about 300 maybe 400 yards in front of you. Also, you'd have to stare at it the entire time to avoid running something unlit over. It's a good aid, but basically at 10-12 knots, by the time you see something on the flir, you're going to run it over.....or **** near..at least in the 103' I do transits on.......
  3. chuckb
    chuckb Senior Member
    Maine
    More night vision thoughts
    There's an interesting although dated blog entry here: http://kensbook.com/aspx/launcher.aspx?msgid=Home&beid=16351.
    I've been involved in FLIR and related projects for military apps, and agree the ability to identify something at speed in time to react is an issue. That said, I've been able to discern a seal from a pot buoy at 30 knots, and avoid either (in a 9M boat).
    Field of View is a big issue. You can get a gimballed stabilized FLIR that can count threads on a uniform at 1000 yards.... but your looking through a straw and its not a useful navigation tool. FLIR also makes a "wide-eye" fixed camera with a 60 degree field of view, which is great because it shows enough of what's in front to allow one to identify the "clear" areas. But... and a big but... the distance at which things are truly visible is not good for high speeds.
    For close in areas (harbors) or doing things like picking up people overboard in the dark, thermal cameras are a huge asset.
    There's lots of companies besides FLIR, and I've had mixed luck with them. I now spec only FLIR for my customers, expensive but you get what you pay for, but only in the non-recreational (>$10K) market...
  4. MaxPower
    MaxPower Senior Member
    At Sea ... Aahhh ...
    I agree with Capt. J ... it's a great aid, but I would not rely blindly upon it.
  5. brian eiland
    Thermal Imaging verses Image Intensifing
    Please correct me if I'm wrong, but isn't FLIR systems primarily based on infrared and thermal imaging?....but not imagine intensification so much?
    I get the impression that the Current Corporation's technology is more 'imagine intensity' oriented, supplemented by termal imaging?
  6. chuckb
    Maine
    Good point re: image intensification. FLIR is purely thermal/IR with an additional day/lowlight channel, most of the folks I work with will wear Night Vision Goggles, and then use the FLIR for zooming in on things... which then leads to having all displays NVIS compatible, another whole area...
    An interesting issue is that IMO approved nav lights on a boat will generally make NVGs bloom, basically rendering them ineffective. There are solutions which one can use on one's own craft, but you can't control whats put on other folks boats. I'm not sure how all that plays out on Current Corp equipment.
    Chuck
  7. MaxPower
    actually it has 2 cameras - thermal & low light ...
    the way i've setup mine is i display thermal on one screen & low light on the other ...
    also, when u go into surveillance mode, the unit scans about 30 degrees (i think) either side continuously.
  8. sagharborskip
    sagharborskip Senior Member
    Sag Harbor, NY
    My first FLIR experience was 2 weeks ago - one of my clients installed one on his 42' Tiara (!) expecting it to enable him to go out at night w/out yours truly (me).
    For me, I was thoroughly impressed by what you COULD see with the FLIR in IR mode. As we were coming back to the breakwater well after dark, a smaller Grady White or Boston Whaler passed a 100 yards or so to our PORT side and continued on ahead of us. With our naked eyes, we could barely make out anything but the nav lights. With the FLIR we could very easily make out the boat, the wake, the heading, etc.
    For the owner, he was a little disappointed you couldn't use the thing to drive by (no surprise there). With 2 Raymarine C120 displays, we had one on GPS and one on FLIR (not my idea, I wanted the radar on the FLIR display). The FLIR is no substitute for radar - it's IN ADDITION to the radar that it can be of use or when navigating an anchorage or in a traffic area.
    The field of view is VERY narrow and, like others have said, not very good for seeing more than a few hundred yards at most. We were trying to see if it could pick up marker buoys at 1000 yards or more and had no luck with that.
    A great tool to add to the tool bag, but not as a stand alone item. I'll look forward to trying it out in other conditions - fog, rain, chop - but I won't be getting rid of the radar!
  9. NYCAP123
    Why in the world didn't he split-screen the GPS with either the radar or FLIR? No way would I give up radar. It could also bring legal or financial consequesces should something happen.
  10. Pascal
    FLIR has its use in some specialized applications and environment but firth typical pleasure vessel I really don't see the benefit
    In the example posted above, while it s "cool" to see the details of a small whaler passing 100 yes away, so what? All inreally care about is swing its nav lights, everything else is a distraction
    Boats (even a small ones), jetties, piers, pilings will show on a radar if properly tuned and set up.
    On most boats under about 100' you don't have enough TRAINED crew to have someone dedicated to monitoring the FLIR Ans my concern is thAt the time my eyes spend onthe FLIR will be less time looking outside of looking at the radar and plotter
    I do a lot of night time running, anywhere from my home waters to new England, including most of the icw over the years. I can't say that I ve ever wished I had night vision equipment. I d rather protect my own night vision by dimming everything to the minimum... You can see a lot of stuff outside especially in developed area where light reflects on the water
    I would get concerned about splitting a radar display to show FLIR a loosing details on the radar
    Pots and debris is a concern in some waters... For pots I d rather rely on cutters although Like everything they are not 100% effective.
    Now on a large boat where you can a have a trained crew up on the bridge who can be focused on one of the display, then it's a nice tool
  11. K1W1
    Where does it say that the smaller boats you run actually need to have a Radar fitted ?
  12. NYCAP123
    No need to have it fitted, but if you have it you must use it.
  13. SHAZAM
    SHAZAM Senior Member
    The Ghetto
    FLIR kicks ass!
  14. sagharborskip
    Sag Harbor, NY
    Aside from Pascal's post that he must have typed with his two big toes...(!)
    It wasn't up to me to split or not split the screen - it was just an observation that the FLIR was a poor substitute for radar.
    Aside from that, the FLIR was of little use while underway and was great once we hit the breakwater...
  15. chuckb
    Maine
    I think the whole issue of FLIR vs Radar is moot. Radar is a must... period, operating without it in marginal conditions is not an option. That said, IR can pick up stuff Radar doesn't, but only in close... and only some operators can drive and assimilate an IR display at the same time. My vote is that if you can afford both the $$ and the bridge space, go for it, but don't expect it to be magic sauce in and of itself....
  16. NYCAP123
    Knew that. Owners just never cease to amaze me, especially when it comes to using radar. I once came out of B.I. in dense fog, saw a boat barreling down on me, from my port side, on the radar. Hailed on the VHF and sounded my signals. He never responded. I threw our boat into reverse just before his 50+ Azimut broke out of the fog a few feet ahead of me and went past my bow at over 20 kts., then disappeared again. He never even knew he almost hit a 51 Bertram. I look forward to getting to check out FLIR one day. More aids the better. Now we just have to convince people that these are for more than just being able to show one's friend they got a new toy. I doubt FLIR will replace radar any time soon, but I'm sure some will get it instead.
  17. K1W1
    What if it doesn't work?
    Would this stop you leaving port or if it failed underway would you put out a distress call?
  18. NYCAP123
    Let's be serious now. From the cases I've read about on Google searches, what determines culpability in that situation is how long it was inoperable and what efforts were made to repair it. You're not required to use what you don't have. Using radar is considered as part of "maintaining a watch". If you've got eyes, you're expected to use them.
  19. Capt J
    What kind of double-ended question is this, and what are your intentions by asking it? Honestly?????
    If the radar is indeed working, the US coast guard requires you to use all applicable navigational aids that you have. If it is installed it should be on when underway. If it did fail while underway, then one would make do with the aids you do have or possibly anchor until fog lifted or something like that to maintain safety. If it's there I think the US Coast Guard requires it to be operational, but am not sure.
    If it never existed then, no you do not need one by law. Just like if you have a life-raft installed, it had better be certified and current or you will be fined. However, if none exists then there is not a requirement of needing one, until you get to a certain tonnage.
  20. Marmot
    Only vessels >1600 gross tons and towing vessels >12m in length are required to carry a radar.
    Applicable regs:
    33CFR164.53 Deviations from rules and reporting: Non-operating equipment.
    33CFR164.82 Maintenance failure, and reporting
