Click for JetForums Click for Abeking Click for Burger Click for Cross Click for YF Listing Service
News: SUY 110 Yacht Unveiled
Discussion in 'Unique, Custom or New Launches' started by Yacht News, Jul 10, 2025.
  1. New SUY 110 Revealed
    With the SUY 135 already under construction Antonini Navi has decided to expand their Sports Utility Yacht line with the introduction of the SUY 110. The 33.5-meter vessel has lines by Fulvio de Simoni and is already engineered ready-to-be-built. In fact, the yacht can be delivered 22-months from contract signing. Essentially, the SUY 110 is the smaller sibling to the SUY 135 model that is currently in build.
  2. In terms of performance, this yacht is expected to be fitted with a pair of CAT marine diesels. These will run the vessel to an estimated 14-knot top end. Although, if a more environmentally conscious owner signs contract the propulsion setup could be be swapped for a diesel-electric system. Using this setup this propulsion onboard will reduce fuel consumption by 20% for a yacht this size.
  3. The yacht has a 4 deck layout with a lower deck, main deck, upper deck and a smaller sun deck. On the lower deck is where you will find the majority of the yacht's guest accommodation with two VIP cabins and two regular double cabins. On the main deck, you will find the full-beam master suite with a private studio area. On the lower deck there is provision to house up to 6 crew.
  4. This yacht shines with its myriad of deck spaces which are all accessible to guests onboard. Perhaps the aft main deck area with its plunge pool, or the forward bow lounging space or the al-fresco sun deck or even the raised-aft upper deck area all provide different opportunities for relaxation and entertainment of the guests. Given that the vessel is a Sports Utility Yacht then you will expect some tender and toy carrying capability. On the aft main deck this is where many of the tenders and toys will be stored when not in use.
    Antonini Navi
    Località Pertusola
    Frazione Muggiano
    19032 Lerici (SP)
