Click for Mulder Click for Mulder Click for Glendinning Click for Perko Click for Furuno
News: Sirena Yachts Sirena 68 Premiering At Cannes Yachting Festival
Discussion in 'Unique, Custom or New Launches' started by Yacht News, Jul 8, 2021.
  1. Cannes Yachting Festival Debut For Sirena 68
    The Sirena 68 is the newest model on the water from Sirena Yachts and this vessel is going to be making its debut shortly at the Cannes Yachting Festival in September. With a hull design by Frers the yacht enjoys range-extending displacement speeds. The interior is available in a number of schemes which the owner can choose from. In fact below you will see at least two different looks of spaces onboard the Sirena 68. There is the Light inspiration design, Serenity design and Dark Elegance design.
  2. Sirena 68 interior is designed by Cor d Rover and in the selection directly below you can see how the main salon will appear if the owner chooses the Light Inspiration design. It is an elegant space well suited for relaxation and calming of the senses. Subtle, neutral and light colors and tones are utilized in the area to help promote this feeling. The large windows offer ample views outside while permitting plenty of natural light to penetrate the interior. Many of the finishing materials proposed in this particular interior scheme also catch both the artificial and natural lighting in different ways. Some are reflective, softening and radiant.
  3. Below is an example of the Dark Elegance design in the master suite. The master suite is full beam and located on the lower deck midships of the hull. Either side benefits from a large rectangular window. The centrally placed King bed is the center stage of the room serving as the focal point from where the arrangement of the space fans out. The other guest accommodation is also located on the lower deck forward of the master. If you are attending the upcoming Cannes Yachting Festival, you will be able to see this new Sirena 68.
    Sirena Yachts
    Abdi İpekçi Cd. Ada Apt. No: 22/18 K:5
    34367 Nişantaşı
    İstanbul
    www.****************
