Click for Perko Click for JetForums Click for YF Listing Service Click for YF Listing Service Click for Ocean Alexander
News: Northwest 58 By Northwest Yachts
Discussion in 'Trawler News & Launches' started by Yacht News, Dec 3, 2025 at 8:19 AM.
  1. Northwest Yachts Northwest 58
    The model range of the Northwest Yachts fold include the Northwest 52, Northwest 55 and the flagship of the range the Northwest 58. It is a direct expansion of the Northwest 52 and 55 models. Designed with the same exceptional layout and design features, the Northwest 58 features a larger cockpit and increased interior living space. Built with long-range cruising abilities, and spacious living areas, the Northwest 58 provides exceptional comfort packaged in a durable, high performance luxury cruising yacht.
  2. This time the model name matches with the actual length of the vessel with an overall length of 58.6-feet with a beam of 17.2-feet and a draft of just 4.11-feet. 63,500 lbs is her dry load. 4,542 LT of fuel she can carry in her onboard tanks. Additionally there is storage for up to 1,135 LT of fresh water. In terms of construction, the hull and deck are of vacuum-bagged composite construction. She is an expansion from the 55 model and below is what the NW55 looks like.
  3. Onboard it is a three-cabin layout with all cabins on the lower deck. The master suite is located just forward of midships while there is a VIP V-berth in the bow and another guest cabin on the forward port side. The main deck splits between the main saloon on the aft portion of the deck and the wheelhouse steps-up in height via a couple steps. The relaxation part of the saloon and galley share the same general space while the wheelhouse is perched higher and is accompanied by a corner settee and table.
  4. There is also a flybridge area fitted with a pair of helm seats. The port side also carries a built-in settee with accompanying table. Moving aft and down a couple steps will be the open boat deck which is specifically envisioned to store the yacht's tender as it has a built-in crane installed across the beam. However, once the tender is launched to the water the space is free to set-up as desired.
    Northwest Yachts
    3116 V Pl
    Anacortes, WA, 98221
    www.northwestyachts.com
