Click for Walker Click for JetForums Click for Ocean Alexander Click for Cross Click for Furuno
News: Ginton Design ADA 50 Third Hull Technically Launched
Discussion in 'Unique, Custom or New Launches' started by Yacht News, Sep 19, 2024.
  1. ADA 50Z Third Hull Technically Launched
    The third unit in the ADA 50Z line of yachts has been technically launched and will continue build through the fitout phases until delivery in 2026. This one is being built under hull number NB103 with a design by Uldas Yacht Design and Naval Architecture by Ginton Naval Architects. The interiors are by Luca Dini but no interior renders have been released for this build so far.
  2. The interiors should be accommodating for up to 12 guests given the 6 cabin layout. Up to 10 crew will also be accommodated. The master suite on the main deck forward position will be full beam and have a balcony. The tri-deck yacht has a sun deck being part of its aluminum superstructure. The hull has been fashioned in steel. At nearly 50-meters long and nearly a 9-meter beam and a 2.6-meter draft the ADA 50Z series has petit-like frame while keeping an internal volume under 500 GT.
  3. Two significant social areas onboard will be on opposite ends of the yacht. Firstly, the beach club area on the main aft deck will feature the now popular fold-down bulwarks to form expanded terraces for the beach club region. On the lower portion towards the swim platform the dip pool will form the center piece. At the other extreme of this yacht, the foredeck, there is another pool that is glass-fronted and flanked by sunpads. Aft of the pool is C-shaped al-fresco social area.
  4. MAN diesel powerplants are onboard to run the third hull. A top speed of 15-knots and cruising speeds around 12-knots have been calculated. Tender storage is in a garage in the bow and holds the main tender along with toys. This is the third hull earmarked for 2026 while the first and second hulls are anticipated for delivery in 2025.
    GINTON Naval Architects BV
    Nieuwe Gracht 37
    2011 NC Haarlem
    THE NETHERLANDS
    www.ginton.com
