Click for Delta Click for Glendinning Click for JetForums Click for Mulder Click for YF Listing Service
News: Fabbro Yachts Building 35M Trideck Flagship
Discussion in 'Unique, Custom or New Launches' started by Yacht News, Aug 28, 2024.
  1. 35-meter Flagship Under Construction For Fabbro Yachts
    Fabbro Yachts is working on their 35-meter tri-deck flagship yacht. The yard is known for their smaller F45 line of yachts but is now going 'big' on this F115. Construction started in earnest in Spring, 2024 and is expected to continue until launch in 2025. Naval Architecture has been done in-house while the exterior design is the work of CORD Design.
  2. Internally the yacht's design is built on neutral tones and colours with only vibrancy offered through red accents in the master suite and dining room. There is the opportunity to have a 6 cabin layout on this vessel for guests and owner which will culminate to sleep 12. It is a full tri-deck design with good exterior al-fresco spaces for guests as well as light and airy interiors with sophisticated design styling.
  3. Those exterior al-fresco spaces feature heavily towards the aft of the vessel where multiple levels offer guests the opportunity to layout and destress to varying degrees as well as privacy. At anchor, there is a built-in transformer in the swim platform that can be deployed into the water offering ease of access to and from the yacht. Seating is also available under the substantial overhang along with space for sun loungers and other small loose furniture items. Stairs take you to the main deck level where an elevated platform has bench seating and cocktail tables. This is a perfect spot at sunset. The remaining stairs take you to the aft upper deck and then to the sun deck which is the highest guest deck.
  4. The yacht will have a pair of MAN marine diesel engines that will provide enough power for a top end speed of 15-knots. Regularly she will be cruising a about 12-knots making leisurely passages rather than sprinting between marinas or anchorages. Anchorages will also be no problem with this vessel as the draft is approximately 2.15-meters. At 35-meters, finding a berth in the marina will also be no issue. Look out for this vessel coming in 2025.
    CORD Design
    57 Simcoe Street South, Suite 1-H
    Oshawa, ON L1H 4G4
    www.cord-design.com
