Click for Ocean Alexander Click for CL Yachts Click for Burger Click for Northern Lights Click for Glendinning
News: Burger Boat At FLIBS 2026
Discussion in 'Burger Yacht' started by Yacht News, Oct 27, 2026 at 12:16 PM.
  1. Burger Boat At The 2026 FLIBS
    Burger Boat will be at the 2026 edition of the Fort Lauderdale International Boat Show (FLIBS). If you are going to be in attendance, you can visit this esteemed American shipyard at their position in the show at the Bahia Mar Yacht Builders Tent #812. Hot on the lips of many is the Burger flagship; the Burger 180. The yard is waiting on you to make your customizations for this new build and meeting them at the upcoming FLIBS is the perfect opportunity to do so. This is a monumental project for Burger Boat and you the customer can be part of that history.
  2. A bit of information on the Burger 180. This superyacht comes with six staterooms, including a lavish full-beam Owner's suite and five exquisite guest staterooms. This permits ample space for you and your guests to relax and unwind in style in personalized and luxurious accommodation. Three internal decks and a massive sun deck account for the guest related deck spaces. Besides the large sun deck, the aft main deck will also be a highlight aboard with guest space offered on the aft unlike previous Burger Boat builds. The 180 will be taking inspiration from the aft decks of many smaller models across the industry blending pool time with relaxation, dining and just on-the-ocean experiences all within the same area separated by a few steps across the terrace area.
  3. The flexible 720 GT interior décor allows you to customize your yacht to suit your unique tastes, whether you choose your own designer or opt for an interior designed by the renowned De Basto Designs or Patrick Knowles Design. In terms of performance the yacht is fitted with a pair of Caterpillar 3512C IMO Tier II engines allowing a cruising speed of 14-knots and a 4,000 nautical mile range at 11-knots.
  4. Burger Boat has a number of buildable designs and concepts in the works too. The Burger 147 ATRIUM is one of them. The name suggests large interior spaces centered around a bespoke atrium area onboard. Burger Boat Company and Evan K Marshall are in collaboration on this. On this model you will probably see a six cabin layout but there is an option for a layout of 7 cabins for guests onboard if required. 147.6-feet with a beam of 29.4-feet and a draft of 7.06-feet are the principle dimensions. The aluminium construction is ABS/MCA Classed and the yacht can carry up to 10,000 US Gallons (38,900 LT) of fuel onboard.
  5. If you are going to be at the show you can visit Burger to discuss the ATRIUM project, the Burger 180 or even the 120-foot raised pilot house concept they have. The design is a collaboration with Gregory C. Marshall Naval Architects. The hull shape has been optimized with Computational Fluid Dynamics and the final configuration has been tank tested at the Wolfson Unit in the United Kingdom to confirm performance characteristics. This design can also move forward to the build stage. 25.7-feet on the beam and a shallow draft of just 5.03-feet are the other main dimensions. Her initial design calls for an on-deck owner’s stateroom with large windows, his and hers heads, a private office and four guest staterooms, each featuring an ensuite head. The two aft guest cabins feature king-sized berths while the two forward guest cabins are convertible, allowing each cabin to feature a king-sized berth or two twin sized berths. Pullman berths are also installed in the forward guest cabins.
    Burger Boat Company
    1811 Spring Street
    Manitowoc, WI 54220
    www.burgerboat.com
