Click for Nordhavn Click for Westport Click for Burger Click for Ocean Alexander Click for Abeking
News: Build Commences On Second G24 Motor Yacht.
Discussion in 'Unique, Custom or New Launches' started by Yacht News, Jul 23, 2025.
  1. Keel Laid On Second G24 Motor Yacht
    The 23.99-meter or 79-foot motor yacht from the new G24 line has commenced build. The keel has now been laid for construction to continue on the hull. This is the second hull in this G24 line of yacht. The first has been under construction as Project 'Veronika' and that is anticipated for delivery later this year. Hull 2 is being built under speculation and is available for sale asking €7,500,000 currently.
  2. The second hull will follow in similar fashion to Project Veronika with regards to the relative high volume interiors. In this size category it is sort-off uncommon to have an interior volume of approximately 115 GT. On the accommodation side, there is a set of 4 double guest rooms to sleep up to 9 guests. These rooms are going to be spacious for a vessel this size.
  3. In terms of performance, the new yacht will have a pair of MAN V12 engines which are paired to ZF Pods. The anticipated top speed with this set up is 27-knots. Not only do you have a relatively spacious platform but one that can get you from your breakfast spot to your lunch spot with little fuss. These yachts will be a source of pride for the yard given that even though the company has been doing sub-contractor work for nearly 20 years, Project Veronika will be the first yacht they build to bear the badge of the yard. Naturally, the second hull will carry the same badge.
  4. The yard says that hull 2 can be completed within 24 months from the stage it is currently at. Since there is no buyer currently any customer that comes aboard the project will have reduced wait time on their new yacht. The yacht is being constructed in all aluminium to a design by VYD Studio. The Naval Architecture is the work of Arrabito while the interior is being formulated by Michela Reverberi.
    VYD Studio
    Piazza Silvio Benco,
    34122 Trieste TS
