Click for Perko Click for Abeking Click for Ocean Alexander Click for Burger Click for Cross
News: Baglietto 42M Superfast
Discussion in 'Baglietto News & Launches' started by Yacht News, Feb 1, 2021.
  1. 42-meter Baglietto Superfast In Build
    This new 42-meter vessel looks super-fast on the renderings and will be super-fast in real life when it comes to fruition in the middle of 2022. This is the 42-meter Baglietto Superfast currently under construction at the Italian yard. The design comes from the boards of Francesco Paszkowski. The lines from their pen will formulate into a 28-knot Aluminium beast.
  2. Onboard there will be room to sleep up to twelve at maximum if needed in the five cabins that are spread between two decks. Two twin cabins on the lower deck have pullman berths. Additionally there are two VIP-grade doubles for other guests to utilize. On the main deck is the full-beam master suite located towards the forward portion of the vessel. Ample glazing lines the sides of the room allowing for the best accommodation views onboard. Triple MTU 16V 2000 M96L engines are fitted. Two will run to shafts while the central will be attached to a booster jet. The planned top speed is 28-knots with this setup. We look forward to seeing this yacht hit the water in 2022.
    Baglietto spa
    Viale San Bartolomeo 414
    19126 La Spezia
    www.*************
