Click for JetForums Click for Cross Click for Mulder Click for Perko Click for Burger
New Owner - General Operations Checklists
Discussion in 'Carver Yacht' started by Tranquility, Jun 3, 2013.
  1. Tranquility
    Tranquility New Member
    Winthrop Harbor, IL
    Hello everyone,
    I am the new owner of a 1995 Santego 380. Does anyone have some basic checklists that I can use for operating the boat? I'm looking for something that would list things to perform when entering the boat connected to shore power, I.e. power switch settings, getting ready to depart on a trip, ie. what to have turned on, what order to turn on different systems / switches? I think I have a basic understanding but don't want to have something switched on that should be and something switched off that should be on.
    Please let me know. Thanks!!!
    1)Engine room check:
    Oil, Transmissions, Racors, condition of belts and hoses, fire extinguisher, general look around for anything worn or just not looking right. Make sure bilges are clean and there is nothing that might obstruct your bilge pump.
    2) Turn on blowers, let run for 4 minutes.
    3) Preheat, then start generator. Let run for a few minutes to warm up, then switch power over from shore on pannel (should be idiot-proof).
    4) Turn off power at pedistal and then disconnect shore cord.
    5) Start you motors and let them warm up.
    6) Turn on electronics.
    7) plot your course.
    8) Turn on what you need (don't need water? leave waterpump off, etc.
    9) Check that your throttles and steering are operating properly, also gears and bow thruster (if you have). Center your wheel.
    10) Untie your lines. (Sounds stupid, but you'd be surprised.)
    11) Pull out slow and go have fun.
  3. Tranquility
    Winthrop Harbor, IL
    Thanks for the info. My generator is not starting when on shore power. I haven't tried starting it without being connected to shore power. When I took delivery of the boat everything started and ran OK. The generator ran for the three hour cruise home. I am wondering if I need to have shore power turned off or even disconnected before trying to start it.
    Should I have the AC and DC switches off before starting and the turn the to ship power if the generator starts?
  4. NYCAP123
    Someone mentioned a setup last week that didn't block the generator and shorepower from delivering juice at the same time, which sounded crazy to me, but he didn't mention that the gen might be blocked from starting while shorepower is being supplied which would make sense. It's possible that you have such a system. Normally though you can start the gen while the shorepower is connected and then you either throw a rotary switch or throw down the shorepower switch, slide over the block bar and throw up the gen switch to transfer your ac power. If you have one of the later setups, which would be normal, then there may be a breaker on the gen that got tripped. If the gen is cranking, but just not turning over you probably just need to push the pre-heat for up to 10 seconds. If you're getting nothing I'd look for that breaker.
    Also if you get nothing when you hit the switch its battery could be turned off.
  5. Tranquility
    Winthrop Harbor, IL
    I checked the generator. Its a Kohler 6.5 unit. The white switch was in the up position. In that position the generator would not start. The switch showed on. I changed it to the down position and the generator started right away. The switch shows off on the indicator. I'm going to go through the manual and see what the switch is for.
    Will post more later....
    The switch is for AC power. The generator started with the switch off and I did not have AC power. Should I start the generator and then try to switch the switch to the on position? Or should I switch the switch to the on position and try starting the generator?
    The manual says the system is overloaded or there is a short. There was nothing on the generators so I assume there is a short.
    I'll keep trying...
  6. NYCAP123
    Your description is a little confusing to me, but it sounds like you may be dealing with a situation similar to what I described before, and that's your fail-safe to keep you from drawing juice from shore and the gen at the same time. Any way you could post pics of that and your panel? It sounds like a transfer switch, transferring power draw from shore to gen.
  7. Tranquility
    Winthrop Harbor, IL
    The generator started when off shore power. It also started when on shore power. The switch is for AC power generation. I did not get AC power because the switch is off. I did not know this. I need to try to start the generator with the switch on. I'll try starting it on shore power and then off of shore power.
    I did notice a GFI outlet in the head that doesn't seem to be working properly. I was not able to trigger it and reset it.
    I may replace it and see if it is the item that is causing a short.
  8. RB480
    RB480 Senior Member
    New Buffalo, MI
    Frank, try putting the AC power switch on the main panel in the cabin in the off position, not on shore power and not on gen power then start the generator.
    I would leave the white switch on the panel in the up/on position at all times since you have a rotary switch on your interior electrical panel.
  9. seldomdry
    seldomdry Member
    Stillwater MN
    Ok. I have a 1995 355 AC. Just went through Genny issues. On my Gen the rotary switch on the Gen cover is hooked to the Gen battery. In ON position it gets start power. I am asumming you have two 30amp meters and rows of breakers on your control panel. Shorepower 1 has all 120v breakers. Shorepower 2 has Air Condition and water pump breakers. The switch from Shore Power to Genny is not a rotary manual switch, Carver used a auto relay. There is one for each shore power cord in your panel. Deltrol 900 series P/N 20241-83. 100.00 if bought through dealer. 29.00 on line. When I leave dock I will start Gen after Shore power unplugged. Hope this helps a little.
  10. zeeshan66
    zeeshan66 New Member
    Trinidad/Toronto/Ohio
    here's some info from a pdf I found online... (not all will pertain to you)
    Before you set off, take a few simple tips for trouble-free boating.
    • Check that your boat is in good condition and meets Boat Safety Scheme
    standards (see page 40)
    • Make sure you and your crew know how to handle the boat – and that
    you know how to handle it on the waterway you’re using
    • Get local information from the navigation authority before going onto
    unfamiliar waterways. On rivers, get information on stream conditions
    and any tides
    • Plan your cruise and allow enough time to complete it without rushing
    • It’s not a good idea to cruise in the dark or when visibility’s bad – if you
    do, take extra care
    • Make sure you’ve got full tanks of water and fuel
    • And remember – alcohol impairs your judgement and makes accidents
    more likely
    Equipment checklist
    Make sure you know where to find these things:
    • Lifebuoy, lifeline (if supplied), lifejackets or buoyancy aids
    • Anchor – for rivers – the rope and chain together should be at least six
    times as long as the deepest part of the river
    • Fire extinguisher and fire blanket
    • Emergency shut-offs for battery, gas and fuel
    • Bilge pump
    • Emergency light
    • Mooring ropes – long enough to stretch from your boat to the bollard
    and back, even when you’re in a deep lock
    • Mooring stakes and hammer
    • Horn
    • First aid kit
    • Boat pole or hook
    • Gangplank
    • Windlass
    Start the engine, keep it in neutral and allow a few minutes for it to warm up before you move off. Untie the front and back mooring ropes from the bank, but leave them tied to the boat, coiled and ready for use. On rivers, untie the downstream rope first. Make sure your ropes can’t trail in the water and get caught in the propeller. Don’t forget to stow the mooring stakes and hammer. Check the area is clear of boat traffic then push the boat away from the bank so you can make a clean get away, with your propeller in deep water. In shallow water, push the back of the boat out, then reverse away until there’s room to straighten up.
    When the boat’s straight, go into forward gear and accelerate gently
    to cruising speed. On all waterways, you drive on the right. In
    practice, on most canals, you’ll keep to the centre of the channel –
    it’s shallow near the edges – unless there’s another boat coming
    towards you.
    Always slow down when passing anglers and other boats.
    Don’t let your boat create a breaking wave or a lowering of the water
    along the bank just ahead of the boat. These are signs that you
    should throttle back to prevent damage to the bank and disturbance
    to moored boats. Excessive speed can dislodge mooring pins.
  11. RicF
    RicF New Member
    SoCal
    The First thing I did when I closed on my 3807 was to hire a captain for the day. She took us through all the systems, procedures, line and boat handling. She laid out the manuals and took us through everything, including procedures, checklists, locating all the through hulls, pumps, valves, basic maintenance, etc.
    Yes she was expensive but I figure she saved me many thousands, so in the overall scheme of things - it was inexpensive and I'll do it again on my next boat.
