Click for Westport Click for Northern Lights Click for Mulder Click for Ocean Alexander Click for Glendinning
New owner 1982 44' Viking
Discussion in 'Viking Yacht' started by Al Perna, Jul 7, 2023.
  1. Al Perna
    Al Perna New Member
    Cheraw
    Hello , after 20 years without a boat I'm back :) very happy I was able to buy this boat and look forward to keeping her up and enjoying her . Any tips on preventive maintenance would be appreciated. Thank you in advance
  2. MBevins
    MBevins Senior Member
    Windsor On. Canada
    I'm assuming this is the aftcabin varient?
  3. Al Perna
    Al Perna New Member
    Cheraw
    she is , I did fail to make that clear .
  4. MBevins
    Windsor On. Canada
    I've owned my 1987 for 23 years,
    Feel free to ask questions here or vis PM
  5. Al Perna
    Al Perna New Member
    Cheraw
    thank you . Looks like the boat has not moved in 3 months or so and there is no record of maintenance of any kind .
    besides a haul out for the bottom I'm not sure what to replace prior to the ride which is 80 or so miles up the ICW from Beaufort SC.
    I plan to bring 12 or so fuel filters just in case , i will change the oil and inspect the bilge pumps and replace if old . Any other ideas or suggestions?
  6. MBevins
    Windsor On. Canada
    First question to you, since a new purchase.
    Did you get a boat survey and an engine survey?
    Engines should be 6-71s, they're pretty bullet proof but should be surveyed.
  7. LM Viking
    LM Viking Member
    Michigan
    You may want to replace impellers if uncertain when they were replaced last. You definitely don’t want the engines overheating on your trip. I understand detroits in general do not like that.
    chesapeake46 likes this.
  8. PFalkner
    PFalkner New Member
    connecticut
    You might want to flush raw water cooling system, change raw water pump impellers, and when first starting engines be prepared for stuck injectors that could cause out of control engine rpm. Your raw water cooling will be the most common issue to overheating on the trip
