Click for Burger Click for Nordhavn Click for Walker Click for Ocean Alexander Click for YF Listing Service
New multihull yacht?
Discussion in 'General Yachting Discussion' started by catmando, Dec 5, 2008.
  1. catmando
    catmando Senior Member
    Arlington Tx
  2. Jorge Lang
    Jorge Lang Senior Member
    Looks like a sweet ride. I say they put a couple of MTU 16v2000CR just for fun. With that, can anyone come up with an estimated cruising speed?
  3. catmando
    Arlington Tx
    "The SC117 will be propelled be either surface drives or water jets. The yacht's optimum cruising speeds will be in between 40 and 50 knots and exceed 60 knots."
    If you click on the 'SC117' button it will give you some speeds. They say a max of 65kn which is what, 75mph? However they don't say what engines they will use. I suspect a big diesel power package as you said. 2000hp diesels with probably make 60kn with jet drives and 65 with Arnesons or BPMs.
    They don't say if hydrofoils will be used in the tunnel but that might be advisable on such a big cat. The Prout 64 catamaran has them as an option but has much less performance without them.
  4. catmando
    Arlington Tx
    The bad thing is there's no contact information on the site, so even if you wanted to buy one you can't. :rolleyes: :mad:
  5. NYCAP123
