Click for Westport Click for Ocean Alexander Click for Furuno Click for JetForums Click for Abeking
New Launch: Inace Yachts 36.57M Expedition "Far Far Away"
Discussion in 'Yacht News; Builds & Launches' started by Yacht News, Mar 1, 2012.
  1. Inace launches 36.57-meter expedition yacht
    Think about a "Far Far Away" expedition and you have the name of the newest launch from Inace Yachts, (hull 576). She is also the flagship of the company. The finish colors on the yacht are gray on the hull and white on the superstructure making for a normal but eye-catching scheme.
    The design is by Luiz de Basto with distinctive play with different sloping angles around the superstructure. Forward sloping bridge windows add a nice design touch while complementing some of the other angles. "Far Far Away" has been built in both steel and aluminum with her superstructure set far back allowing for a long foredeck.
    The foredeck is enables Far Far Away to stow two similar-sized tenders served by a robust crane. The yacht isn't a speedster so a comfortable top speed of 13-knots has been estimated using her dual CAT marine engines. She is an expedition yacht and she is meant to be efficient. 6,000-nautical miles at 10-knots efficient.
    On the inside, Far Far Away will carry ten guests in five staterooms all located on the lower deck, a Master, two doubles and two twins. The new yacht should be delivered to her owner(s) by May, 2012.
    Inace Yachts
    INACE
