N-ZO 760 is the perfect combination of luxury, adaptability, durability, and comfort. Designed by the renowned Italian designer, Vittorio Garroni, the N-ZO 760 is specifically created to meet the needs of recreational sailors around the world. The exclusive N-ZO 760 line is fortified with the latest in Zodiac Nautic technology, which is designed to provide you with the safest and smoothest on-the-water experience possible. The deep V-hull, enhanced with the exclusive Zodiac Nautic Shell technology, provides unmatched sea-handling capabilities. The deck-layout was designed with passengers’ comfort and safety in mind, offering safe on-board mobility to passengers while docked or moving. To ensure maximum comfort and spaciousness, the N-ZO 760 features the new “Air Console”, minimizing space and maximizing interior capacity. SPACIOUS AND ADAPTABLE A modular design makes the best of the available space. The bow of the N-ZO 760 can be converted to a large sun-deck in a matter of seconds. The rear of the boat is equipped with a large seating area, easy access to the swim platform, and versatile storage solutions, creating the ultimate entertainment platform. The new N-ZO 760 represents your needs in the best possible way, using versatility to adapt to your passenger’s desires while maintaining superior seaworthiness, spaciousness, safety, and comfort. Specifications: Length: 24' 11" Beam: 10' Hull Weight: 3373 lbs Motor Weight: 575 lbs Capacity: (18) Persons or 4585 lbs Tube Diameter: 26" Separate Air Chambers: (6) Underdeck Fuel Tank with 75 Gallon Capacity Fabric Type: Hypalon - CSM, Commercial Grade, 1670 Decitex Slide-On Tube System Standard Hull / Tube Features Include: Deep V Fiberglass Hull (22 Degree Deadrise) Self-Draining, Molded Fiberglass Non-Skid Deck Fiberglass Bow Molding with SS Anchor Roller Lockable Anchor Stowage / Bow Storage Locker Under Console Storage Stern Locker Storage Aft Bathing Platform Aft Cockpit Seating Area with Cushions Pull Out Teak Table Leaning Bolster with Storage, 12V Outlet, Cutting Board and Sink Well Electric Underdeck Bilge Pump Navigation Lights Engine Well Cover Ski Mast - Roll Bar, Stainless Steel Bow Mooring Eye, Stainless Steel U-Bolt Transom Eyes , Port & Starboard, Stainless Steel U-Bolts Stainless Steel Dock Cleats, Fore & Aft, 2 Port & 2 Starboard High Profile, Triple Rubbing Strake Removable Tubes for Easy Storage, Repair or Replacement Semi-Recessed Inflation Valves with Replaceable Valve Inserts Standard Features Include: Fiberglass Stand-Up Console with Footrest Hydraulic Steering System Forward Console Seat with Cushion, Storage Underneath Rocker Switch Panel on Console 12-Volt Receptacle Easy Access Battery Cut-Off Switch Foot Pump Repair Kit (2) Paddles Battery Tray Fuel / Water Separator Digital Yamaha Command Link Tachometer Digital Yamaha Command Link Speedometer Only one available at this price. Limited offer. $91,050.00 with LoadRite Tandem Axle Aluminum trailer Location: Waterford, CT USA
