Click for Cross Click for Mulder Click for Abeking Click for YF Listing Service Click for Furuno
Need to replace Priming Pump Fuel Decal
Discussion in 'Technical Discussion' started by CSkipR, Jan 28, 2020.
  1. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    The decal shows how to slide lock and the direction the handles should be in to Run or Prime. They were accidentally painted over and would like to replace. Any ideas?
  2. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    Maybe save them? By taping off around the decal or not, by rubbing decal with Lacquer thinner and rag or Acetone to carefully remove the paint only.
  3. CSkipR
    CSkipR Member
    They were painted over and when I tried to remove the paint with acetone it removed the lettering of the decal.
  4. Oscarvan
    Oscarvan Senior Member
    Chesapeake Bay
    Take a picture of one, laminate.
  5. Capt Ralph
    MAN decal? Call MAN and get a fresh one.
    Racor also.
    Print shops can make them also.
  6. CaboFly
    CaboFly Member
    Seattle
    Skip- The fuel priming pumps on my Cabo are Reverso. I would look at their website or give them a call.
  7. Beau
    Beau Senior Member
    Beaufort, NC
    You could also take a rendering to a local decal shop and have one or two made. Dunno what the cost would be? Maybe the net offers some opportunities too? Also add a diagram to your on board manual for reference.
  8. d_meister
    d_meister Senior Member
    La Conner, WA.
    Print your own on 3M dual purpose transparency film at home. 3M CG5000. I've printed on the film in reverse with a color ink jet printer at home, spray painted a background on the image side, then glued the thing down with either double-stick tape or spray adhesive. The reason to do it in reverse on the adhesive side is that many home printer inks are water soluble.
  9. CSkipR
    CSkipR Member
    Thanks I got the decals through Cabo Yachts old printing company they used in CA many years ago.
