Click for YF Listing Service Click for Burger Click for Northern Lights Cick to Clean Black Water Click for Delta
Naiad versus Quantum Stabilizers
Discussion in 'Stabs, Tabs & Gyros' started by balboa, Feb 1, 2008.
  1. balboa
    balboa Guest
    Can anybody share experiences with either one of these brand's fin stabilizers? Do they work as advertised? Any maintainance problems?
    They seem offer a very similar product but while Naiad posts some testimonials, Quantum actually lists all the ships that carry their stabilizers.
    And well, Quantum equipment is made in The Netherlands.....
    Thorwald
  2. 'RoundTheHorn
    'RoundTheHorn Senior Member
    Salish Sea
    What happened to Rolls-Royce?
    Hi Thorwald,
    I can't offer any insight into the Naiad versus Quantum question, but I am curious about the post in your blog regarding Rolls-Royce stabilizers. You seemed rather positive in your description of their equipment. Have you decided against them? If so, can you share with us what changed your mind? Thank you.
  3. K1W1
    I have not had any direct dealings with NAIAD Systems.
    I have however had extensive dealings with the Quantum 4 Fin system.
    I am currently looking with Mike Perkins over there at Quantum at fitting another 4 fin set to a conversion I am looking at.
    Their equipment works well and is finished absolutely beautifully. They also offer an integrated Hydraulic Power Pack which is worth looking at if you are doing a big hydraulic refurb on your trawler.
    Off Topic- Thorwald, I saw some of your posts on the expedition yacht blog. It's a well presented story of your conversion trials and tribulations to date. Thanks for sharing the details with everyone. What size helicopter are you hoping to operate off this vessel when she is done?
  4. balboa
    balboa Guest
    What happened to RR?
    Well, it certainly is my preferred solution but it's also about double the price and 4x the weight, and a lot more space is required.
    If I were an oil sheik or had a lot of shares in Royal Shell, I'd probably go with RR; meanwhile, I'll have to go for something more economical. I've also looked at the Quantum Hydraulics rotory stabs, those that use the Magnus effect. But I'm a little concerned about maintainance issues (and lack of yachts using them). Also, I'd still need 4 rotors in my case; if I need 4 anyway, I might as well go for fins that have no fast-moving parts.
    I've been in touch for some time with Mike Perkins and he has been very helpful and quick in follow-ups so QH has a big edge with me now.
    Thanks for the positive comments on my blog. As far as the heli goes, a Bell Jetranger would fit but we prefer to use a nice used Eurocopter AS350b3.
    And, we may start out with an R44 :).
    The deck - particularly near the life raft boarding area will actually be widened a little bit, to cover the deck below and make space for a tender crane. Of course, for the heli operation, the issue is tip clearance with the exhaust stag. Nothing will change there but I have landed in tighter spaces :)
  5. BMcF
    BMcF Senior Member
    Maryland
    Just a quick note on that: The Magnuss-Effect rotors are 'only' for low (< 6 knots..or thereabouts) and zero-speed control (something they apparently do well) and are retracted at cruising speeds. So they must be used in conjunction with fins to cover the entire speed range. Thus the question becomes: "Fins and rotors?..or fins alone?". The answer to that, is a matter of how much low-speed and at-anchor control is required and how much when underway. The rotors do not repace fins; they augment the fins in a system designed to provide roll control at any speed.
  6. The Reverend
    The Reverend New Member
    La Paz Mexico
    Apart from a personality clash with one of the Quantum techies I have found their product and support as a whole in a league above any other of the stabiliser systems I've dealt with in recent years. I don't believe it is an accident that in the last few years that they have dominated the market in high end stabilisation systems for yachts.
  7. balboa
    balboa Guest
    correction on Maglift rotary stabs
    Thanks all for your great feedback. I'm going with Quantum, needless to say :).
    But, let me correct the above: they work fine with speeds up to 12 kn (not just 6) although they do become more effective at slower speeds (unlike traditional fins). My situation is perfect for the Maglift, especially now that they will build a bigger system for my particular case (see post on my blog). I'll only need 2 rotors and they can be placed midships where I have lots of space in fuel tanks. When I don't need them, they retract.
  8. BMcF
    BMcF Senior Member
    Maryland
    Having been involved in some of the background work on the earlier Mag rotors (not the current Quantum production hardware), I recalled that there were limitations for the rotors at vessel speeds around the range I stated. But if QME says they are still effective at speeds to 12 knots, then I'm sure they are, since they are certainly not known for making claims that are not supported.
