Click for Westport Click for Delta Click for Westport Click for Glendinning Click for YF Listing Service
Mtu Engine Choice
Discussion in 'Engines' started by DON GREER, Jul 12, 2008.
  1. DON GREER
    DON GREER Member
    My port is Vancouver, British Columbia, Canada.
    Good, bad or indifferent, I would like to hear any experience regarding MTU 10V200M93 diesel engines.
    Service – maintenance – operational – noise levels – vibration - any issues..??
    I am considering having these engines installed in a 75 ton boat.
    According to statistics:
    PERFORMANCE AND FUEL CONSUMPTION 10V 2000 M93
    SPEED IN RPM 2450 2200 2000 1200
    MAXIMUM POWER KW 1120 1080 1000 0475
    BHP 1500 1450 1340 0635
    POWER PROPELLER CURVE (N3)
    KW 1120 0820 0615 0135
    BHP 1500 1100 0825 0180
    FUEL CONSUMPTION
    g/kwh 0214 0207 0208 0214
    On propeller curve L/hour 288.8 204.5 154.1 034.8
    Gal/hour 76.3 54.0 40.7 9.2
    According to my experiences in MTU/DD warranty support and cost of maintanence I will never EVER recommend an MTU/DD product to any of my future clients due to a terrible warranty issue with them on 2 different boats. I would go with CAT, who stands behind their products and warranties things right here and right now.
  3. DON GREER
    DON GREER Member
    Mtu Cat Man
    OK..I will accept that. Now I am down to CAT or MAN.
    Any advice there...?
    I would recommend CAT C30's or C32's depending on what you're looking for. The MAN's will be a little quieter and consume slightly less fuel. BUT, parts are more costly as is servicing. The servicing is also more extensive and expensive. Cat's will have more torque, parts and certified mechanics can be found worldwide, easier to fix (less complex), most of your usable parts (filters etc.) are common throughout many of the engine series and can be found easier. The Cat's will weigh a little more then the mans. In all of the yachts I have run, the MAN's seem to do better in fast vessels (expresses, etc.) and not so well suited for heavier/slower vessels due to the torque differences.
  5. DON GREER
    DON GREER Member
    Cat Man
    Thanks for the input....
    The 1500's will give me 20 knots cruise but for the most part I will likely run at either 16 or 12. I operate in the Pacific North West. The boat name will be Memor Esto....
    I pay for good advice with good brandy.....
    Cheers.....
