Click for CL Yachts 99X Click for Abeking Click for YF Listing Service Click for Westport Click for Burger
MTU coolant hi temperatures
Discussion in 'Engines' started by Andy tug, Jun 28, 2016.
  1. Andy tug
    Andy tug New Member
    Savannah
    I'm getting highs temperature alarms and can not find a solution. I cleaned the heat exchanger and bleed the air out. I can see any external leaks and I've not got any high lube oil alarm associated with this or charged air as well. No additional oil or coolant added. Any suggestions out there?
  2. AMG
    Most common problem is a plastic bag on the intake..?
  3. Andy tug
    Andy tug New Member
    Savannah
    No I don't think so the engine is closed plate cooler type that has a raw side along side a coolant side which flows through heat exchanger.
    So you're saying you are keel cooled? Hows your tubing on the hull? Have you had a diver clean all of the barnacles and growth off of it?
    If it's raw water cooled, first thing to check and change (if they haven't been done in 2 years or 200 hours) are your raw water impellors.
  5. K1W1
    I do not read the guys post as a statement that he is keel cooled, I read that he is saying raw water flows through one side and coolant through the other.
    It may come as a surprise to him but these type coolers get fouled with marine growth just like a shell and tube one.
  6. Andy tug
    Andy tug New Member
    Savannah
    This a 16 cycl. MTU 6000 hp tug it has a raw water side that that run adjacent to coolant side that is a closed system through a plate cooler. My thought is that Hi temp coolant alarm is the possible result of faulty/worn fresh water pump or thermostat not upping as designed this condition only happens when hooked up. Any other thoughts?
  7. Andy tug
    Andy tug New Member
    Savannah
    Also plate cooler recently clean so no problem there.
  8. K1W1
    Is it a single engine installation or does the Tug have two of these engines? Is there anyway you can see the SW flow that is being pushed through the cooler, are the sea strainers clean, are all valves in the system fully open?
    Was it the engine overheating that led to you cleaning the plate cooler in the first place?
  9. Andy tug
    Andy tug New Member
    Savannah
    I think I found the problem the outlet side of raw water piping that goes overboard has a valve. This valve was previously set by the former engineer and thought to be in the so call sweet spot however it was closed down to much not allowing for enough heat transfer.
  10. K1W1
    It is often the simplest thing that causes the hardest to find problems. Glad to read you got it sorted.
