Click for Ocean Alexander Click for Cross Click for Westport Click for Burger Click for Burger
MTU 4000 M73 emergency shut down while docking!
Discussion in 'Engines' started by Saar, Jan 3, 2015.
  1. Saar
    Saar New Member
    Happy new year everybody.
    A couple a days ago, offcorse while docking at the port: both engines shutdown!
    The mains are brand new, both mains shutdown exactly at the same time.
    I am not sure what was the reason for the emergency shut down,
    I would be happy if you can help me out figuring the reason.
    Following are the alerts:
    STBD Main:
    31/12 14:45- SE CAN Bus 3 error/bus 371 +A210-A210
    01/01 14:56- SS Emergency stop
    01/01 14:45- AL Emergency Disengage
    01/01 14:56- SS Security Shutdown
    01/01 14:56- RCS Combined Alarm
    01/01 14:57- MG Eng. Speed high/Low(clutch)
    01/01 14:57-SS Emergency Stop
    01/01 14:57-AL Emergency Disengage
    01/01 14:57- SS Security Shutdown
    01/01 14:57- AL RCS Combined Alarm
    Port Main:
    31/12 14:47- SE CAN Bus- 3 Error/Bus 372+A210-A210
    31/12 14:48- SE CAN Bus- 3 Error/Bus 372+A210-A210
    31/12 14:22- DL 372+A110-A110
    31/12 14:22- RL 372+A110-A110
    01/01 08:28- DL 372+A110-A110
    01/01 08:28- RL 372+A110-A110
    01/01 14:56- SS Emergency Stop
    01/01 14:56- AL Emergency Disengage
    01/01 14:56- AL RCS Combined alarm
    01/01 14:57- AL RCS Combined alarm
    01/01 14:57- SS Emergency stop
    I really appreciate your help guys!
    Have a good one.
    Saar
  2. captholli
    captholli Senior Member
    In The Bilge
    I assume your Blue Tec equipped? if so you have excellent trouble shooting in the B.T. menus that will explain the cause for your code outs. If not than it sounds like an excellent question for MTU electronics division and or your vessels Monitoring manufacturer. Controlled area network PLC problems or voltage dip? Certainly nothing that you want to repeat whether your coming to the dock or in heavy weather.
  3. olderboater
    Trying to say this constructively but I don't understand why you're asking us? No documentation? Neither MTU or Westport was able to answer you?
  4. Saar
    Saar New Member
    I have tried to check at the documentation but I could not find this alert.
    The next step is going to be MTU and Westport.
    Thank you for your help
    Saar
  5. dennismc
    dennismc Senior Member
    Vancouver BC
    That's a surprise, if you where passenger carrying as certified vessel, I doubt that shutdown would be allowed, potential loss of life.
    It sounds like a faulty fire system shutdown.
  7. XavierP
    XavierP New Member
    Monaco
    Hi Capt. J, any feedback about your MTU shutdown? Did MTU electronics find the cause of this?
  8. olderboater
    It wasn't Capt J. It was an apparently unconcerned new engineer as he wasn't concerned enough to call MTU or WP, both of whom are available 24/7.
  9. Hendrik227
    Hendrik227 New Member
    Spain
    Hi Everyone, I know this link is old but does anyone know if this above issue was solved? I have the same issue on my yacht that I am working on. TIA
  10. Liberty
    Liberty Senior Member
    Brisbane, Australia
    It looks like an error I once had. The CAN bus tripped out and brought down the engines and generators with it.
    CAN bus was wired to the fire system. CAN bus tripped, which made the fire system trip which then brought down everything. All engines, all electrics, all electronics. Lights, radios etc etc.
    It was on a Riviera. They fitted a fishing rod holder by just drilling a hole in the transom coating without any thought where the salt water would drip. In this case the salt water dipped onto the aft terminator block of the CAN bus network.
    The temporary fix was to pull a manual fuse link and override the shorted terminal block.
  11. Kelvin
    Kelvin New Member
    Nigeria
    I am experiencing such right now in my ship. There was a fire outbreak at the aft engine and lots of sea water was used to quench the fire. The main mtu engine refused to start up after the incident and the LOP was giving ss emergency stop and other error codes, thus making the ECU not to have power. What can be done in this case.
  12. Kelvin
    Kelvin New Member
    Nigeria
    What can be used to check the PIMs.
