Click for Burger Click for Glendinning Click for Nordhavn Click for CL Yachts 99X Click for Westport
mtu 2000 fuel burn
Discussion in 'Engines' started by 68 Viking SF, Apr 8, 2012.
  1. 68 Viking SF
    68 Viking SF New Member
    loreto
    i am considering buying a 70 foot sportfish with MTU 2000 93's and hopefully someone will know the fuel burn at variouse speeds / settings. also any consistant problems with them. thank you, Kent
    16v2000's burn 150gph at 1950 rpms or close to 80% load. A friend of mine put a lot of hours on them, we had a coolant circulation pump go bad at less than 1,000 hours and a couple of injectors. Nothing major.....the first 150 sets of 16v2000's had major issues early on, but they were all solved within the first year.
  3. Capt Ralph
    Get a reputable MTU mechanic to give an in depth engine survey. If any extended warranties are still available, buy into them and keep them as long as you can.
  4. 68 Viking SF
    loreto
    Mtu
    thank you - we will be doing that. sure appreciate your comments. Many times the Captains out there know much more then the "experts" they are the ones to ensure there is enough fuel for a long delivery. kent
