I make w6 to this engine but in the 2000 rpm I have high exhaust temperature 790 in B side and the cooling water temperature is 90 Please if technical have idea for this problem Mtu 12 v 396 te 94
You're talking of Celsius, I suppose? 90° C is not outrageous for the coolant, if it doesn't rise further at WOT. And the EGT, is it measured before or after turbo? Regardless, if I just had an MTU dealer doing the W6 service, I'd want them to take care of this problem PDQ - as well as others, if any! PS: hang on, the 396 is already at its max rated rpm when running @2000, 'innit? What temperatures do you read at your normal cruising speed?
