Click for Westport Click for Walker Click for Ocean Alexander Click for YF Listing Service Click for Burger
Motor yacht refit/tuning
Discussion in 'Technical Discussion' started by Michael_s, Nov 6, 2010.
  1. Michael_s
    Michael_s New Member
    Russia
    My boss is going to buy 23-27m motor yacht and redesign and tuning it (interior)
    Could you advice some shipyards in Turkey, which could do it good, but not expensive?
  2. vivariva
    vivariva Senior Member
    Istanbul, Turkey
  3. MYCaptainChris
    MYCaptainChris Senior Member
    Melbourne Beach FL
    Consider Malta if you can get her down there.
  4. Michael_s
    Russia
    I think aluminum/steel.
    But for wood company link thanks too. Maybe he will buy the second wooden boat.
    He wants to repaint yacht and change furniture in it. It's the main task
    I also found the list of Turkish shipyards for refit
    There are 20 shipyards. Which of them is best?
    If my boss buy the boat which locatad in Napoli , it will be easear way to Malta, than in Turkey.
    Are the aompanyes in Malta do their work better and cheaper?
    Thank's for answers.
    Michael.
  5. vivariva
    Istanbul, Turkey
    The link that I have sent you is a company that makes wooden furniture and designs interiors on a project basis. They do not build wooden boats.
    Repainting an aluminum/steel boat is not that difficult, you would not need to go to a shipyard in Istanbul to do it. There is a company called 'Yachtworks' in Turkey, with facilities in Didim Marina, using the marina's 400 ton crane. I have included the links:
    www dot yachtworks dot info
    www dot dogusmarina dot com dot tr/didim
    Here below are two shipyards (not recommended for a yacht), in Istanbul:
    www dot gemak dot com
    www dot tuzlagemi dot com
    I do not recommend the yacht being serviced in these shipyards as they do repair work for cargo ships/tankers and might charge a higher price than a yard servicing boats. You are leasing a portion of the work area, so they will try to balance the opportunity cost of placing your yacht there. My advice would be go to Malta or if you're in Turkey, try one of the southern marinas like Alacati, Orhaniye, Didim or Netsel (Marmaris) marinas' service facilities.
    Cheers, VR
  6. MYCaptainChris
    Melbourne Beach FL
    I won't give a recommendation for Malta as it's been so long since I've been there and with so many changes over the last few years I don't know one yard from the next.
    However they have their own yachting directory online which is a great source of info.
    I've taken a steel yacht there and had welding, paintwork and carpentry all done to a great standard. I also know that MY Osprey which is a wood yacht, is based in Malta for each winter for it's refit.
    I hope this helps
    www dot maritimedirectory dot com dot mt/
  7. Michael_s
    Russia
    vivariva, MYCaptainChris
    Thank's !
    And the other question.
    If, for example, my boss buy white yacht and then he will repaint it into black color, should he change documents?
  8. Garry Hartshorn
    Garry Hartshorn Senior Member
    I am doing a major refit on a 35 meter in Turkey at the moment. If you are interested PM me.
