Click for Westport Click for Burger Click for Abeking Click for Burger Click for Abeking
McKinna 57 Pilothouse
Discussion in 'McKinna Yacht' started by Oscarvan, Jul 11, 2019.
  1. Oscarvan
    Oscarvan Senior Member
    Chesapeake Bay
    Any of you Captains ever operate one of these? There's a few on YW but there seems to be little real information out there on them....
  3. Oscarvan
    Chesapeake Bay
    Thank you, that appears to be the 70', but it informs of the quality of build. I am also looking for the "bad and the ugly" after 20 years....
  4. YachtForums
    My bad. I'm juggling a member mailer behind the screen today. Overlooked the size. :(
  5. Oscarvan
    Chesapeake Bay
    No prob. Looking for some of the skippers here that may have done a delivery or two on one....
    I have. I managed a 65' Mckinna several years back, still in touch with the current owner a little. They're ok, wouldn't put them at the height of quality and of course the 65' is the 57' that's stretched, which is the 70' which is the same hull stretched even more. Boat had 2 chillers and was under a/c'ed and hard to get really cold. The electrical system was a completely over complicated mess of wiring, solenoids, etc. Entire boat ran off of an inverter, so if you lost shorepower it would start drawing off batteries, if they got below 21 volts, inverter would shut down, batteries would be dead, and resetting shorepower, the inverter wouldn't come back on to charge the batteries or provide shorepower, so we had to install another charger just for that purpose. The fuel system was another typical overcomplicated mess with 20+ fuel valves in the engine room that weren't labeled. Also had those air stabilizers that didn't work much in a decent or real sea (because air compresses!). But was a fairly good seaboat, albeit a tad on the wet side. Cruised at 20-21 knots with 3196's.
  7. Oscarvan
    Chesapeake Bay
    Thanks Capt J.... that's the kind of stuff I'm looking for.
  8. boaterholic
    boaterholic Member
    Welaka, FL
    Reviving this thread...
    I'm kind of interested in a 1999 model year 57. Can anyone provide any current info, good or bad, on the model and things to look for on a survey?
    Also some general questions. Anyone know what is a comfortable cruise speed when I need to get somewhere a little faster, on boat with 450 Cummins?
    How about what is a good hull speed for fuel efficiency and to enjoy the ride? And what are expected fuel burn/mpg at slow speed and at normal cruise speeds?
    Propeller diameter and pitch info? 4 blades I assume. One I recently looked at it appears the shaft was about 2 1/2" diameter.
    This particular boat is not stabilized. Anyone know how they are with beam seas or at anchor with a swell?
    Thanks for the help!
  9. Robert Maddux
    Robert Maddux New Member
    Fortt lauderdale
    Is there anyone in Fort Lauderdale who Knows Mckinna Yachts well. I am in the process of aquiring a 2006 72
