Click for Westport Click for Burger Click for Nordhavn Click for CL Yachts Click for Glendinning
marine head / toilet maintenance
Discussion in 'Technical Discussion' started by Beau, Aug 5, 2011.
  1. Beau
    Beau Senior Member
    Beaufort, NC
    Has anybody used or heard of baking soda being periodically run thru the heads and lines to help keep the system fresh?
  2. m2m
    m2m Senior Member
    newport ri
    baking soda no but white vinegar yes
  3. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    Vinegar. But let it sit in the lines as long as possible.
    Otherwise diluted muratic acid if the hoses are filled up with mineral deposits.
    Does your head/s use salt water to flush? If so, and if there is no strainer on the incoming flush water line, organic matter can build up in the bowl rim and rot causing the head to stink. In that case, you need to take the bowl off and flush the rim out real well and then install an inline strainer on the in coming flush water line so it would happen again.
