Click for Westport Click for Burger Click for Ocean Alexander Click for Delta Click for Nordhavn
Marine Carburator
Discussion in 'Technical Discussion' started by bigear1, Jun 21, 2010.
  1. bigear1
    bigear1 New Member
    Jacksonville,FL
    We have a 38' Chris Craft Corinthian with twin 454 crusaders. The engines have required some work and one needed a new Carb. The original quadrajet was replace with a Holly 4 barrel. I don't believe this is a marine Carb. Is there a difference and are there any safety issues?
  2. Marmot
    Life or death ...
    What happens when your automotive carb has a stuck float?
  3. bigear1
    bigear1 New Member
    Jacksonville,FL
    I really don't know. What happens?
  4. tunnelvision69
    tunnelvision69 New Member
    slidell,la
    the main difference in a marine carb is the use of J tubes for the bowl vents instead of strait tubes. the J tubes force fuel that overflows the fuel bowl into the throat of the carb to stall the engine rather than let it leak onto the engine through the flame arrestor. a stuck float can be deadly without J tubes.
  5. bigear1
    bigear1 New Member
    Jacksonville,FL
    Can the Holley carb be fitted with j tubes?
  6. tunnelvision69
    slidell,la
    yes you can if you can find some J tubes they just press in place. not sure if this will protect you from insurance companies or the coast guard though.
  7. NYCAP123
    Insurance companies love to find non-marinized parts when it comes time to pay claims...or NOT.
  8. CaptTom
    CaptTom Senior Member
    Palm Beach to Ft Lauderdale
    Who did the work for you? Did a licensed or marine mechanic do the carb replacement for you? If so, I would take it up with him. If you or a buddy did the work, then pay the bucks and get a marine carb to prevent a potential tragedy later. A little dirt can sticjk a float and make the bowl overflow. Seen it happen on cars and it can happen. Good luck.
  9. 805gregg
    805gregg New Member
    Ojai, Ca
    Holley makes marine carbs, you can get them from JEGS.
  10. Seafarer
    Seafarer Senior Member
    Hudson River
