Click for Northern Lights Click for Walker Click for Furuno Click for Westport Click for YF Listing Service
Manual Overrides in Aviation
Discussion in 'YachtForums Yacht Club' started by Kevin, Mar 3, 2021.
  1. Kevin
    This thread has been split from a discussion about manual overrides on yachts.
    That sentiment seems to be pervasive these days, going far beyond yachting.
    I'm sure you are referring to a certain Aircraft.
  3. Kevin
    Yeah for sure, that's a worst case scenario...
    But it's starting to show up elsewhere too.
  4. David Helsom
    David Helsom Member
    Sturgeon Bay/Fort Lauderdale
    I’m curious about the aircraft you are referring to?
  5. bobhorn
    bobhorn Member
    Kemah, TX
    Does the model number start with a 7?
  6. Kevin
    The one that was in the news for well over a year, the 737 MAX.
  7. olderboater
    No, a new 737 problem.
    Edit. Not 737, just Boeing in general.
  8. David Helsom
    David Helsom Member
    I was curious because I fly the Max and very glad it’s back in service. What’s the new 73 problem?
  9. olderboater
    A United 777 made an emergency landing after an engine explosion resulting in United grounding all 777's with P&W 4000 engines. Another engine exploded in the Netherlands. A 757 made an emergency landing in Salt Lake City. Those were all within three days.
    Now a 777 has made an emergency landing in Moscow.
  10. David Helsom
    David Helsom Member
    This has been an ongoing theme with the P&Ws. That and they say things come in threes.
  11. olderboater
    But that was 3 + 1 = 4
  12. FlyingGolfer
    FlyingGolfer Member
    NC
    Engine failures occur periodically. The interesting thing about the 777 incident is the failure was not contained by the cowling. Bad juju. An Airbus 380 had a similar incident a couple years ago. Not supposed to happen. The Turquoise incident report is going to be illuminating. Uh...will there be a report? If so, by whom?
  13. Kevin
    Ok, gotcha'.
    I was referring specifically to the problem with automation taking control out of the hands of humans.
  14. Norseman
    Norseman Senior Member
    Back to the 737 Max crashes?
    The humans forgot to hit the Stab Cutout Switches.
    Every Boeing machine I have flown has 2 guarded Cutout Switches, just in the case the Stabilizer has a run-away: It takes 2 seconds to hit the switches and stop the stab.
  15. David Helsom
    David Helsom Member
    Precisely. It was not a Boeing issue. It was two pilots who had no business being in the pointy end of an airliner issue.
  16. FlyingGolfer
    FlyingGolfer Member
    NC
    This is the Great Undiscussed Issue in aviation. The unsuitability of many non Western crews. The unwillingness to challenge the Captain’s authority or think outside the box.
    Scott W likes this.
  17. mapism
    mapism Senior Member
    Sardinia
    Commercial aviation is full of pilots who could have never written a book like Highest Duty.
    But assuming that because of this there was no issue with a Company that over the years, strictly for greed reasons, drifted to having their products designed by clowns and supervised by monkeys, well, that's either biased or naive.
    And call me cynic if you wish, but I smell the former.
  18. David Helsom
    David Helsom Member
    Not trying to hijack or cause thread creep.
    I’m curious about maritime accidents reports and how they compare to aviation accident reviews. Aviation reports will always assign partial fault to the pilots because the aircraft crashed or was damaged. There is some twisted logic in this. Even in Sully and Stiles case they faulted them for not choosing to return to La Guardia. Is it the same in maritime accident event reviews? If a report came out on the Go event and it’s strictly mechanical failure would they still fault the CA for not doing more to prevent an impact?
    Obviously I’ve not read any maritime reports but I’m sure some of the pros here have.
  19. Scott W
    Scott W Senior Member
    Florida
    FWIW, there have been PLENTY of NTSB reports on fatal accidents that assigned zero blame to the flight crew. Sometimes there are simply catastrophic, non-recoverable mechanical failures that doom the plane. TWA 800, AA FL261 & AA FL587 all come to mind immediately.
  20. David Helsom
    David Helsom Member
    Please reread the AA 587 accident reports to include the FAA’s conclusions and you’ll find you are inaccurate. A complete rewrite of transport aircraft handling was published as a result of that accident. Specifically rudder pedal usage. In those reports the pilots “incorrect” rapid rudder pedal reversals caused the vertical stabilizer to depart the airframe. I say incorrect because before that day what CA States and FO Molin who was flying did was correct procedure in attempt to recover from wake turbulence. As for TWA 800 way to much speculation as to what really happened there. However incorrect usage of center tank fuel pumps was a contributing factor according to the conclusions. Also causing a procedural change in fuel pump switchology.
