Click for Burger Click for Ocean Alexander Click for Abeking Click for Northern Lights Click for Nordhavn
Man V 12 question
Discussion in 'Engines' started by JWY, Aug 5, 2010.
  1. JWY
    JWY Senior Member
    Looking for info on MAN V12 1300hp, 1993.
    What is life expectancy before rebuild? Can it be run at lower rpm/speed for fuel efficiency without build-up or shortening of engine life? What is its sweet spot? Fuel consumption?
    Thanks!
    Judy
    The sweet spot I've seen is usually around 1950 rpms on these. Yes it can be run lower speed and cuts out 1 side of the motor when the turbo's not really working (around 1000 rpms and less), if I'm not mistaken. I was told engine life was 5000 hours in a SF. Fuel consumption in a 57' Bertram was between 90-100gph for both at 1950- 1970 rpms.....it seemed to like 1970 for some reason. Queiter and more fuel efficient then typical 3412's of the same HP.
    Only issues I remember was these would blow/break the metal high pressure fuel line coming off of the injector pump and fill the bilge with diesel. However MAN came out with a newer design that fixed the problem and there shouldn't be any left out there with the old design anymore.
