Click for YF Listing Service Click for Glendinning Click for Westport Click for Ocean Alexander Click for Nordhavn
MAN R6-800 Starboard throttle no command indication
Discussion in 'Engines' started by Helmi Rahman, Jul 25, 2019.
  1. Helmi Rahman
    Helmi Rahman New Member
    Cambodia
    My boat recently had a lightning strike and since then my starboard engine is not able to see any reading and take command on throttle.
    I hav change the ECU, MPC, SFFR and even a new throttle however it is still the same.
    Anybody has experience this and knows if there is other Terminal board in the engine room that requires checking?
  2. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    Did you check the fuses on the top of the engine? On mine there are 3.
  3. Helmi Rahman
    Cambodia
    Hi there,
    I have checked the fuse it is well. I need to know if the common ignition has anything to do with the engine monitor and throttle command.
  4. CSkipR
    CSkipR Member
    I can say on mine if the ignition will not come on neither will the engine monitor or throttle command. Have you checked the emergency button on the front wall of the engine room. The red or black round knob.
  5. Helmi Rahman
    Cambodia
    Yes i have checked the red knob. And my engine can actually start just that the monitor screen and throttle unable to command
  6. CSkipR
    CSkipR Member
    I’m sorry beyond my knowledge.
