Click for Glendinning Click for Delta Click for Mulder Click for Furuno Click for Mulder
MAN engine alarm
Discussion in 'Engines' started by Ilrivero, Jan 19, 2012.
  1. Ilrivero
    Ilrivero New Member
    Venezuela
    Hi there,
    Anyone with previous exhaust gas turbo alarms?
    One of my D2876 LE405 engine's exhaust gas turbo alarm goes off and engine slows down If I run the boat over 1850 RPM, if I stay up to some 1800 RPM nothing happens, as soon as I go over 1850 RPM I get the alarm.
    Someone told me they go off when incrustation is present but have new antifouling and the bellows, props, all is very new and clean
    Any ideas?
    Not much help for MAN engines in this area…
  2. Beau
    Beau Senior Member
    Beaufort, NC
    Unscrew the sensor and put in a meter, then run it to see actual temps
  3. NYCAP123
    Had it happen with a new Riva I ran one day. Shut it down, brought it back up, got home and stayed away from that boat since. Sorry, but I don't have a clue on the cause (my guess would be a bad sensor) or the cure, but Beau's suggestion sounds like the right first step.
  4. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    My guess is the sensor is bad. I have Man engines as well and had similar experiences with sensor going off at certain rpms or temperatures. Swap it with the same one on the other engine and see what happens.
  5. Donzi 54
    Donzi 54 Member
    Point Pleasant, NJ & Morehead City, NC
    Excellent idea.
  6. Ilrivero
    Ilrivero New Member
    Venezuela
    Hey thanks to you all,
    I swapped the sensor with the other engine, no difference, same problem port side.
    Two weeks ago I had to install a new water maker and while the boat was haul and block, we went ahead and cleaned metals again, sanded the props and left them shining.
    Incredibly, it took care of the problem, no more alarms on the port engine.
    It’s amazing how sensitive these sensors could be, the props where clean but not polished.
    Since you guys reinforced my primary thought, I went ahead and ordered new sensors, even further, ordered one for each engine, you know, if one goes bad the other engine will too.
    How smart I am !!, I now have two spare sensors, didn’t use any….
    Thanks to you all, and have fun, keep boating !!!!!!
    Ignacio
  7. CSkipR
    CSkipR Member
    That prop cleaning may fix it temporarily but I doubt for very long. At least now you have a couple of new sensors to replace the one should it reoccur. Good luck.
  8. sunchaserv
    sunchaserv Member
    Carefree, AZ
    Maybe the sensor is doing its job. Are you able to achieve and hold rated max RPM with existing props, without EGT or water temps getting into the red?
  9. Beau
    Beau Senior Member
    Beaufort, NC
    Ilriveo
    You've got expensive engines there, screw in a temp meter and be sure of what's going on. Just my 2 cents.
  10. Capt Ralph
    Beau has a solid thought. Follow up any error with a simple and reliable tool. Resistance in wet, dry, loose, old wires can change daily.
    I've been around some sensor issues and most of the time, it is the sensor. Found some bad connects in the harness and at the bulkhead box a few times.
    Only once did I ever find an engine problem. And like you should; believe your indacations... Slow down, shut down, but save that motor.
    Don't guess at a fix. MANs put a lot of performance. But that sensor and computer stuff is there for a reason, to help the operator save the engines.
    Has anybody mentioned yet, MANs are very expensive to fix. More for those that ignore alarms.
  11. Capt J
    It sounds as if the boat is over-propped and over-loaded, which will definately cause high EGT temperatures. You need to take the boat out and run top RPM and make sure it makes recommended RPM's, I'm willing to bet it doesn't, and if it doesn't you need to take pitch out of the propellors so that it does.
    What kind of boat, what hp and how many hours on the engines.
