I understand for earlier threads that the MAN 1200hp LE406, 1200 HP is the very last development of their fully mechanical engines, produced for decades and widely regarded as very reliable. From earlier threads I also read that the engine needs a rebuilt at some point (running hours), depending on usage. What would be the typiscope of such a rebuild? My engines now have close to 3 000 hours on them (sits in a Princess/Viking 20M from 1999), most of these at low loads.
Treat them well, keep them happy with clean good oil, do the standard maintenance by the book, keep the cooling system clean and run them. Do not worry too much for the next 5.000-10.000hrs.Monitor oil and coolant condition and amount. If anything changes noticeably figure out what´s up.
I was looking at a boat with the identical engines, called MAN and asked the same question: 'how long before overhaul'. MAN told me to have the engine checked thoroughly, which means oil samples, boroscope, compression test, check the turbo, pressure test the oil cooler, check / clean the intercooler (if it has one), check all the connections and after that service the engine properly. They told me that if you service the engine on a regular basis these engines can last up to 50.000 hrs. However, that is commercial use, where the engine runs basically all the time. If the engine has been maintained well the engine will last for many hours more.
Low loads really does not mean better (IMO). When your tuned to make 1200HP, efficiencies at 400HP are not the best at that load (40% or less?). Yes, you may be making better MPG but a fully mechanical engine may not be combusting the fuel completely at low loads. Usually not good for pistons, rings & liners. This is why oil labs and bore scope inspections are so important. These help predict time to overhaul before a major failure (new engine) happens. Commercial rated engines are matched and tuned to a operating load and run there it's whole life. You need 463 HP, tune there (only there) and see many thousands of hours. Yes, these life spans are impressive but the recreational engine can sadly never compare.
