Click for Nordhavn Click for Westport Click for Abeking Click for Northern Lights Click for YF Listing Service
Man CR900's Intercoolers
Discussion in 'Engines' started by CSkipR, Jul 28, 2019.
  1. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    Just had the heat exchangers and the intercoolers removed to be cleaned. Heat exchangers cleaned up well and pressure tested good. Both intercoolers pressure tested good although one had some corrosion and rust on it. Any ideas as to where this would come from if no leaks during pressure checks.
    Age. The way water sits in it when the engine is not running, some air sitting in there instead. IDK.
  3. Capt Ralph
    Corrosion in the air side could be from condensation.
    Same for on its exterior.
