Click for Mulder Click for YF Listing Service Click for Westport Click for Delta Click for Burger
Man CR900 how would rubber chunks get into my oil cooler
Discussion in 'Technical Discussion' started by CSkipR, May 1, 2018.
  1. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    Had the engine oil cooler removed to have the gasket replaced because of a slight oil leak. When they removed the oil cooler they found chunks of rubber inside that appear to have been a broken up round rubber gasket. Any idea how this would have traveled to the oil cooler and what it maybe. No other oil leaks.
  2. 30West
    30West Member
    Holland, Michigan
    Round rubber gasket like an O-ring, or like a flat gasket? Was it on the water side or oil side?
  3. CSkipR
    CSkipR Member
    It looked like it was more a round flatter gasket possibly tapered. Not like an o-ring. Going to have to confirm today but pretty sure it was the water side.
    It might be the gasket on the end of the heat exchanger......do not quote me on this as I'm not that familiar with the insides of MAN's but I believe they have a rubber isolater gasket on each sides of the heat exchanger and that's how they get away without using any zincs in the raw water cooling system......
  5. CSkipR
    CSkipR Member
    Yes it was definitely the water side.
  6. motoryachtlover
    motoryachtlover Senior Member
    smithfield, VA
    CSkipR are you done with Comachee Cove? I would like your thoughts on your experience there. If you would rather not post here, you could PM me. Hope all went well.
  7. CSkipR
    CSkipR Member
    I kind of think it might have been the thermostats that we replaced two years ago. Two of the three a portion of the rubber was missing and chewed up.
  8. CSkipR
    CSkipR Member
    Sent you a pm.
  9. Capt Ralph
    Is the usual tech still working on your MANs?
  10. CSkipR
    CSkipR Member
    No
  11. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    Is the cooler raw water cooled?
    If so, sounds like pieces of the raw water pump impeller to me.
  12. Capt Ralph
    Now that that slob is off of your boat, Clean all up and go boating with a smile.
  13. ychtcptn
    ychtcptn Senior Member
    Lighthouse Point, FL
    Raw water impeller pieces
  14. Pascal
    What's the raw water flow? If the oil cooler is before the heat exchanger, chances are you find impeller pieces a lazy mechanic (or captain) didn't bother looking for
  15. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    Something useful to know about Comachee Cove?
    -Chris
