Click for YF Listing Service Click for Cross Click for Westport Click for Burger Click for Ocean Alexander
Mahogany Railing
Discussion in 'Chris Craft Roamer Yacht' started by cajunroamer, Jan 3, 2006.
  1. cajunroamer
    cajunroamer New Member
    Atlanta, Ga
    I am in the process of replacing the mahogany railing on my 1960 35' Roamer. Does anyone know where I can find mahogany railing?
  2. Hal Swinehart
    Hal Swinehart New Member
    LaSalle, Michigan--Toledo Beach Marina
    I wish I had an easy answer.
    About 3 years ago, I purchased a custom cut piece of Philippine mahogany, approximately 2x4, 11 feet long, from a local millwright shop here in Michigan, for around $40.00 (if I recall correctly). If I wanted new railing, I would go to them with a sample and get a price for them to make it.
    Is your railing missing, or so bad that it needs replacing? I've seen some pretty ugly wood clean up beautifully with some sanding and bleaching. A little elbow grease might be easier (and less expensive) than replacing.
    Another option is to visit the boneyards. Occasionally, someone also posts that they are parting out an old Roamer, but that doesn't happen often.
    Good luck.
    (BTW, I have a 1961 35' Regal Sedan.)
    Hal
  3. alloyed2sea
    alloyed2sea Moderator
    Alex, VA
    Parts, parts!
    Heck, you neednt find a Roamer - CC used the same railing parts on most of their pleasure cruisers - and they made alot of them: boneyards!:p
