Click for Northern Lights Click for Cross Click for Abeking Click for Delta Click for Perko
Looking to Buy Carver Aft
Discussion in 'Carver Yacht' started by millswf01, Jul 2, 2011.
  1. millswf01
    millswf01 New Member
    Summit North
    I need some basic advise. I am retiring in two years so I am looking to buy a 35' (or however someone wants to measure it, sometimes called 40') Carver aft cabin to mostly live and cruise on the east coast. I have looked at a few from 1988 through 2005 and would like to stay under $100K. There seems to be a lot of decent vessels on the market which makes me a little leary. Of course I will get a survey before buying. Is there something wrong with these manufacturer and models? Any advise or comments would be appreciated.
  2. wscott52
    wscott52 Senior Member
    SE Florida
    You might want to read this:
    http://www.yachtsurvey.com/boatreviews/Carver370.htm
    Some people disagree with his conclusions and others say Carver has improved their quality in recent years. The few Carvers I've been on, all under 40' and 1980s models, felt cheap. You do get a lot of boat for the money. With a good survey and no expectation of taking it to the Caribbean or further it might serve you well.
  3. RER
    RER Senior Member
    Newport Beach CA
    Not necessarily. I think the economy might have something to do with it.
    The intended use of a 35' - 40' aft cabin Carver is not coastal cruising. They are built for use on lakes, inland waterways, and marinas. It's more of a floating RV with wife pleasing interior comfort. It can still get you from point A to point B ...just be sure you've got good weather. You will have a lot of choices. Consider spending a little more for a boat that's in better condition. Most of the 35's are gas boats. As you mentioned, it's actually over 40' ...and weighs over 20,000 lbs. Unless you're never going to leave the dock, go with diesel.
  4. NYCAP123
    Look through the Carver threads here. A lot has been written. Bottom line is that their good point is their spaciousness. Their weakest point is their seakeeping abilities. They're good for what they're intended for, bad if you think they'll go where a Hatteras will go.
  5. Fireman431
    Fireman431 Senior Member
    East central Florida
    That ONE survey has been bouncing around since 1997 and some people continue to take it as gospel. Anytime someone mentions they want to look at a Carver, that gets posted again. Want to buy something? Someone will post something negative about it. Looking at a Meridian (Bayliner)? They will post states from the 80's. Looking at a Bertram? They will send you a link to the one that's sitting at the bottom of the ocean. As a Carver owner (2001 374 Voyager), I have had nothing but positive experiences with mine.
    I will offer a little insight on MY experiences with the gas/diesel debate. I was torn between the two, especially in a 40' boat. I spoke with many, many experienced large boat operators and they ALL had the same questions and ALL gave the same answers.
    What is the intended use of the boat, where are you boating, how hard do you intend to push it, what are your estimated trip lengths, and what is your mechanical experience?
    In my situation which is local cruising, weekends, and two 250 mile trips each year, they all said go gas. If I were using it as a fishing boat, work boat, or running 14 hour days a few times per week, then I should go diesel. Maintenance is cheaper on a gas boat, but is required a bit more often. Replacement engines are 1/3 of the price and most work can be done by you if you have average mechanical knowledge. Diesels will last longer, but are more expensive. They run cooler than gas and will go longer time between major needed work. The 'average' person doesn't have diesel mechanical apitude, but that can be learned. Depending on your location, fuel prices will flip back and forth as to which is cheaper. Diesels are more reliable, bur gas is quieter and less offensive while running (exhaust).
    It's true that Carvers are a fair seas boat. Would I want to constantly be out in 4' seas? No, I would want a Bertram or Hattaras. But, that is not my venue. I'm in inland rivers and the ICW, perfect for my boat. Plenty of room, beautiful fit & finish, ease of maintenance (reliable), and it looks good. I only wish I had an aft cabin instead of a convertible. They are a bit more roomy and stable. Also look at Silverton, Meridian, and the like.
  6. millswf01
    Summit North
    Thanks for your inputs
    Thanks everyone for your responses. You know how it goes, you look at what's out there and then you see something that seems to make sense and the aft cabin models seem to make sense to me for what I want to do. I am divorced and not interested in getting hooked again so I don't have to worry about what the wife thinks. I just want to get away from it all and enjoy traveling by myself and sometimes friends and meeting other people who are not involved in the rat race. The Carver seems to make sense since I won't be in any hurry to get to someplace because it will be there when I get there. I don't plan on cruising on rough seas, know how to listen to a weather report, so I really don't know if I really need a Hatteras or Grand Banks or Viking. I guess what I am saying is that the RV without wheels seems that it will be good enough for me. Any other comments or suggestions or just joshing around are welcome. I can take a joke.
  7. NYCAP123
    Sounds like you've got a good plan. Good luck. One suggestion, look into mail forwarding services. X-wives hate late alimony payments.:D BTW, that Jackson Marina isn't the one up here is it. If it is, get in touch before you try to go through Moriches.
  8. timjet
    timjet Member
    Tampa, FL
    I love my '98 355 ACMY with Cummins Diesels, wife does too.
  9. tommyfmu
    tommyfmu Member
    Freeport, NY
    One argument I've heard from a Santego 38' owner friend, is he prefers his engines in the back for ease of access in case they need to be pulled, over the aft cabin. Entitled to his opinion, I found that having my gas engines in my salon didn't make any difference when I changed out my port engine recently; just a little logistical adjustment, having to remove the rear window and rail at the aft deck.
    IMHO the amount of space gained with the aft's are equivalent of a convertible or mariner of about 5 feet greater.
  10. NYCAP123
    Right on point on all counts. On larger boats they just cut a hole in the side of the hull, slide them out that way, slide in a new and close it up. It's really no big deal. I've seen it done in about 3 hours in commercial operations. The only real drawback for having the engineroom access in the salon is that carpets tend to get dirty if workers aren't careful.
  11. tommyfmu
    tommyfmu Member
    Freeport, NY
  12. NYCAP123
    Welcome to YF. Hit edit and get your phone # and e-mail off there before a crawler gets it. You'll be deluged. Any members interested can contact you via PM. Also, post a pic or some pics, also the year. Good luck with selling this and with your new boat.
  13. cobb-n-cruzer
    cobb-n-cruzer New Member
    Little Rock, AR
    carver 4207 aft cabin
  14. millswf01
    Summit North
    4207
    Sorry but that is a little out of my price range at this time. Just out of curiosity, what is the year of the 4207? I am currently looking into a 1991 3607 aft cabin but no deal has been made so far. Any pictures and additional information may divert my attention.
    Bill
  15. cobb-n-cruzer
    Little Rock, AR
    Re 4207
    It's a 1986 that has been totally updated, and always kept in fresh water. We are the second owner. I'll try to get some pictures together for you to look at.
