Click for Westport Click for YF Listing Service Click for Ocean Alexander Click for YF Listing Service Click for Walker
Life Expectancy for Cat 3412Es
Discussion in 'Engines' started by Jim Rogers, May 24, 2018.
  1. Jim Rogers
    Jim Rogers New Member
    Anchorage, AK
    I have done some reading on this, but was interested in getting opinions on how may hours is a lot on these motors. I have generally read that they are good, reliable motors. One of the boats I am looking at is in the 7000 hour range. I am told a large percentage of them are from running at 9kts. I am told it has been reliable and had good maintenance, and the current owner has owned it for 10+ years. I saw somewhere they I should do a blow-by test to to tell the motor's condition. If treated well and there are no issues, what is a reasonable like expectancy for this motor? What should I be looking for if I have the computer checked for usage history? If there were problems a year or two down the road, would these typically be removed and rebuilt, rebuilt in the boat, or replaced? What are some ballpark costs for a complete rebuild on a set of these motors? I am one that wants to keep things in perfect condition, not band aid repairs.
    It all depends on usage but generally 6-10,000 hours. However, I recently dealt with a set that 1 head dropped a valve seat but cylinder was fine the other one is missing some power somewhere but these are around 1500 hours, but lack of use. Generally they would be rebuilt in place.
    Complete rebuild $40-50k each.
  3. Capt Ralph
    I have always liked the 3412s.
    A good engine survey will offer the better picture.
  4. Pascal
    I put 5500 hours on a pair of 3412Es, about 60% of which at hull speed. They passed survey with flying colors, no smoke and excellent oil analysis
    They can be rebuilt in place as long as access is good and the block is fine.
    I d do a sea trial first and watch the basics starting with smoke on a cold start. Then if it s fine, do an engine survey during which the mechanic will be able to plug in ad check some history and run som tests
  5. Jim Rogers
    Anchorage, AK
    Can you explain this further? I thought it was fine if they smoked when cold or under heavy load. My common rail never smokes, so I am not use to seeing this.
  6. Pascal
    I mean watcbing for smoke on a cold start. Depeding on outside temp they should smoke very little when started and it should clear very quickly. Being in so fl, i rarely started them in anythin under 60 deg. Above 60, by the time i d leave the helm and go aft to look for smoke, it would oretty much have dissipated. Under 60 a little more greyish smoke is ok.
    They should not smoke under load. Unless maybe the operator is heavy handed and jams the power forward. I always accelerate slowly to reduce west n tear
  7. captainwjm
    captainwjm Senior member
    Miami, FL, Cape Elizabeth, ME
    Exactly right.
