Click for JetForums Click for Delta Click for Westport Click for Cross Click for Furuno
Lewmar Hatch Finishes and Quality
Discussion in 'General Yachting Discussion' started by CaboFly, Feb 10, 2022.
  1. CaboFly
    CaboFly Member
    Seattle
    Looking at replacing hatches during exterior refit on my 48 Cabo. I can find the smoke lexan and aluminum frame Lewmar hatches in stock but am unable to find the frosted lexan with white frame Cabo used unless I switch to Bomar.
    How does the quality compare between between Lewmar and Bomar.
    Is the frosted lens preferred over the smoke tinted lens?
    Boat will be in Seattle after refit so heat from the smoke lens is not a primary concern just not sure if there are other reasons most builders use the frosted.
    Appreciate the input. First time replacing hatches. Have owned both in the past as original equipment.
    I would stick with the brand that is in there. Call Lewmar directly and they will make them for you based off the serial numbers in the frame. if you switch brands, none of the screws will line up and that will create a huge mess.
    gr8trn likes this.
  3. CaboFly
    CaboFly Member
    Seattle
    That model is discontinued on the larger hatch. Sams now sells a bomar white frame with frosted they say is drop in replacement. Spendy though. Can get a medium profile aluminum frame with smoke lens from WM. Same dimensions as original. Of course if switch to smoke lens then I will need to replace the small hatches as well that are currently in decent shape but they 15 are years old.
    Are you sure Lewmar and not Bomar?
    Have you talked with Lewmar or Bomar directly?
    discontinued is not written in stone, just a suggestion.
    I know Bowmar will make replacement hatches. You just need that serial number.
    Hatteras and SeaRay used Bomar hatches when I was servicing them. Never messed with a Cabo hatch but just assumed it would be a Bomar hatch.
    I assume Lewmar would also build you a new hatch. But you have to get over that English language barrier issue when you call the UK.
  5. rtrafford
    rtrafford Senior Member
    Vero Beach
    I replaced a hatch and added a snap-in solar screen in lieu of seeking an alternative to the tint. Still get nat light, lose UV and gain privacy.
  6. CaboFly
    CaboFly Member
    Seattle
    Yes 100% certain Lewmar. I taked to Fisheries Supply and they said they could contact Lewmar regarding frosted hatch as special order and no guarantee on timeline. Knowing how disrupted supply chain is I don't have confidence hatch would be here in time. If I can find three new hatches ( two 10's and one 70) that are drop in replacement including screw pattern I will stay with Lewmar and go with smoke lens.
  7. Capt Ralph
    Before July 4, New years?
    If it fits perfect with no mods, Please define time?
    So, Lewmar for sure, you have an interpreter.
    Fingers crossed for you.
    In the mean time, Have you contacted the correct mfg of your boat? Original kids or Hatterass?
    Maybe they have a timely replacement plan already in process. Can not figure you are the only Cabo owner with a hatch issue.
  8. CaboFly
    CaboFly Member
    Seattle
    Sams Marine sells a Bomar and says it is a perfect fit to replace the original Lewmar. I don't want a mix of Lewmar and Bomar hatches on deck. That is just me.
    My post was more in regards to dilemma of moving to smoke finish on acrylic vs factory frosted acrylic style hatch. Is there a good reason builders use one vs the other? I need hatches in 8 weeks when paint is done and I leave the shed.
  9. Capt J
    Smoke you can see through, frosted you cannot. Looks is another reason. You can change the acrylic easy enough, just need to get a plastics shop to cut it......prospect plastics in Oakland Park can do that.
  10. dewald
    dewald Member
    Treasure Island, Florida
    I agree with Capt J. Just remove the old acrylic (in one piece) so it can be used as a template, go to a good shop. They can make you a new one in any color and opacity you want. I did that for my bow hatch last year. If I remember right, they charged me $50.00 and had it for me the day.
  11. rtrafford
    Vero Beach
    If you do this, recommend using Bostik 70-08A for new acrylic installation. You need it to bond, hold, and be reliable.
  12. CaboFly
    CaboFly Member
    Seattle
    Bought a Medium Profile Lewmar Size 70
    Also have two Low Profile Lewmar Size 10's coming.
    Going new as the others show wear on the frame and for what I am spending on new paint job I wanted fresh hatches with new bedding. Thanks for the feedback guys.
