Click for Burger Click for Ocean Alexander Click for Ocean Alexander Click for YF Listing Service Click for Cross
Lazzara crash in California
Discussion in 'General Yachting Discussion' started by Pascal, Jul 27, 2025.
  1. Pascal
    There is a video that’s been popping up of a 80 or so, about 2000 vintage Lazzara crashing into a bulkhead in Marina del Rey, ca.
    the triton claims that the captain was “unable to reach the engine in time” and opted to crash into a sea wall. Yeah I know. You d think a yachting rag would have decent editors…
    https://www.instagram.com/reel/DMoAmKqPr0T/?igsh=bng1ZDk1NnlyaHlx
    these boats had MTUs (12V183s) and I m trying to understand how in case of an engine control failure (possible) neither the emergency shut off buttons not turning off the keys would actually shut down the engines.
    I was on an Azimut one time with an open flybridge, came across from Bimini it was rough so running it from inside, came up on the bridge inside port everglades activated the micro commanders on FB, port engine went into forward and revved to 1500 rpms......takes a second or two to process what's going on, and then in a panic you need to find things.
  3. Scallywag
    Scallywag Member
    Islamorada FL
    I mean... the engine stop button would be the first logical thing.
  4. mapism
    mapism Senior Member
    Sardinia
    Just guessing, but in the event of a major electrical fault, I don't think it's impossible that the only way left for shutting those puppies down is to push the stop solenoids manually - which obviously means directly on the engines.
  5. CTdave
    CTdave Senior Member
    Greenwich CT/ Stuart FL
    Here's a theory. If Capt. or person at the wheel panicked and first, shut the keys off (which wouldn't shut it down), would the "engine stop" buttons still work? I have the same exact set up with engines and controls, but I can't remember if the engine shut offs will operate if the ignition keys are off?
  6. Pascal
    MTUs do shut down where you turn off the keys.
  7. mapism
    Sardinia
    You said she's powered by 183 MTUs.
    The very last version of that series was the semi-electronic TE93, but AFAIK they sold many more of the previous one (TE92), which was still 100% mechanical.
    No idea of what's fitted on this boat, but with the TE92 the stop solenoid is excited to stop, not to run.
    That's why I previously said that a major electrical fault could disable the remote stop (it's irrelevant whether triggered by the key or a button), requiring a trip to the e/r instead.
