Click for Delta Click for Abeking Click for Walker Click for CL Yachts Click for Ocean Alexander
lasico planimeter
Discussion in 'Technical Discussion' started by coastalrb, Jan 16, 2013.
  1. coastalrb
    coastalrb New Member
    in Westbrook ct had to sail back up the channel.
    not able to calculate ft2 with a lasico model 20 A
    tryed to follow the instructions but no luck
    CA = unit
    1 to 1 ratio
    1" to 1'
    unit = .02 x N = square ? What unit, feet, inches don't know
    Robert
  2. K1W1
    Measure a room in your house/office you know the dimensions of. Work out what unit the answer is in based on the answer you already know.
    I have not dealt with Ft and Ins for many years, I seem to recall that there would be 144 sq ins in a foot so an area 5 ft X 2 ft would be 10 sq ft, or 1440 sq ins. The same as if you had used inches all the way and multiplied 60 X 24.
  3. Garry Hartshorn
    Garry Hartshorn Senior Member
    My planimeter has not been out of it's box in many years however try the following
    Draw a series of squares of know sizes and begin with the planimeter measuring them, you will undoubtedly notice that there will be variations in your readings. This is normal and with a little practice you will get better.
    I expect you have an imperial planimeter so when you measure 1 sq inch your reading should be 1.00 this is factor N, when measuring on a drawing this is to scale and it is no longer 1 square inch.
    If your drawing is 3/4" = 1' the N factor of 1.00 is now 256 sq inches or 1.778 sq ft
    Hope this helps
    G
  4. Ward
    Ward Senior Member
    Vancouver BC
    A tip I remember from Kinney's book on yacht design: trace around the shape you're measuring in both directions and average the readings.
  5. Garry Hartshorn
    Francis Kinney recommends averaging several readings but I do not believe that he measures in both directions. Most plain meters only work clockwise
  6. Ward
    Ward Senior Member
    Vancouver BC
    It has been a long time since I read my Kinney book, so it's possible I've got it wrong. It stuck in my mind because I first read (but didn't understand a lot of) the book when I was a kid and it wasn't until much later that I had a chance to try a planimeter and I dug out the book and that's what I think it said, but at this point it's a memory of a memory, so it could be wrong.
