Click for Glendinning Click for Mulder Click for Burger Click for Burger Click for JetForums
Kohler 6.5 Leaking Oil
Discussion in 'Carver Yacht' started by tommyfmu, Jun 13, 2013.
  1. tommyfmu
    tommyfmu Member
    Freeport, NY
    Has anyone encountered significant oil leaking from their 6.5kw other than from around the oil filter seal?
    I've looked all around the obvious places such as oil fill box and seals, drain tube connection, crankcase gaskets...
    The only placed I haven't checked are where it's too tight to see such as under and behind due to space constraints...
    Just wondering if someone came across something stupidly easy to fix, by chance, and don't want to have to take out the whole thing.
  2. sam356
    sam356 Member
    Great Oaks Fairlee Creek MD
    Check your air filter it may need to be replace. The air filter is one that you soak in oil.
  3. Capt Ralph
    The 6.5 gas model used a brass screen for the air filter/flame arrester.
    I remember the oil pressure switch mounted low and maybe hard to see under the mag. Don't remember any pan or crank seal issues. It was a solid block.
  4. dennismc
    dennismc Senior Member
    Vancouver BC
    WOW !! The air filter is one that you soak in oil.
    Never knew that...
  5. tommyfmu
    tommyfmu Member
    Freeport, NY
    I'm supposed to soak the air filter in oil? Didn't read that in the manual.
    What's 'the mag,' and where do I find it to inspect? I can try looking in the manual and check around the switch to see if it's leaking.
    Thanks for the ideas...
    Is this Genny the old 4 cylinder flat top or the newer V2 Kawasaki motor? The Mag I mentioned is the Magneto from the ole flat top design.
  7. tommyfmu
    tommyfmu Member
    Freeport, NY
    It's got the 2 cylinder Kawasaki.
  8. Capt Ralph
    Please scratch my first comments. Thought it was da flat top.
  9. crashgtr
    crashgtr New Member
    nj
    Kohler 6.5 surging when running- need manual
    Does anyone know where to get a repair manual for 6.5 kohler gen in a 1995 carver mariner 330?
    Our generator is surging when it runs and we would like to tune it up and figure out what its wrong with it.
    We just got the boat in May and it didn't come with a manual for the generator.
    Anyone know where I can find one or have any suggestions?
    thanks
  10. tommyfmu
    tommyfmu Member
    Freeport, NY
    I have the owners manual I can email you if you PM me your address.
