Click for Perko Click for Mulder Click for Walker Click for Northern Lights Click for YF Listing Service
Keyway on shaft by coupler
Discussion in 'Technical Discussion' started by CSkipR, Dec 27, 2009.
  1. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    Yesterday I noticed that the port keyway was sticking approximately 1/2" out of the coupler onto the shaft. On the starboard side it is flush with coupler. Not sure it may have always been like that. Any issue with this?
  2. Henning
    Henning Senior Member
    Ft Lauderdale FL
    As long as it is still seated and held firmly in place in the keyway, there is no real issue with it sticking out a bit past the coupler. Just make sure that it's not working its way out because the assembly is loose, because that will lead to shaft damage.
  3. CaptNeil
    CaptNeil Member
    East Coast
    Skip:
    That keyway should be flush or close to it. 1/2" is a lot. I had one pop out about 18 miles out of Masonboro inlet on a 45 Viking. You don't want that to happen it is a real PIA. Do you have any vibration while running? If so you may want to have the wheels and rudders checked for damage. It may have caused the keyway to work it's way loose.
  4. Marmot
    Before you get too worried, take a punch or a screwdriver and see if you can tap the key back towards the coupling. If it moves you need to find out why it is loose. If it is solid, you don't have a problem. Not all keys are the same length and sometimes a replacement key is much longer than the coupling.
  5. CSkipR
    CSkipR Member
    Thanks guys I will see if it moves by tapping on it. I haven't hit anything and have no vibration. All your help is greatly appreciated.
  6. Henning
    Ft Lauderdale FL
    Make sure the shaft is tight inside the coupler as well. Sometimes when the key is sticking out it's because the shaft has backed out a bit. That's the prime concern.
  7. Marmot
    Good advice.
    You can check that quickly by looking closely at the shaft just behind the coupling half, it should not show a "ring" or witness mark where it used to meet the coupling and should not show any longitudinal scratches from being pulled out. If you have any doubt then you are back to disconnecting the coupling half and inspecting it.
  8. CSkipR
    CSkipR Member
    Keyway on port engine slide out some
    I took a hammer and slightly taped it back in. What would the suggestions be on why it was loose. The shaft has not moved as the grounding marks made around the shaft are still in the same spot. No vibrations, haven't hit anything.
  9. Marmot
    Does your coupling half have a setscrew? If so, it is probably loose and the key is slightly undersized or the keyway on the coupling half is slighly oversized or worn.
    It is difficult to give advice on what to do without actually being there to evaluate it "hands on" but if the key moved back in place easily without much force then I would be inclined to pull the coupling half and fit a new key that fits very snugly.
    The key prevents the coupling half from rotating on the shaft and a loose key will allow the coupling to rock back and forth with firing impulses and loads until the fit between the coupling and the shaft wears enough to cause real problems. You may have seen keys that have a shear line along the shaft OD and that is caused by the relative motion between coupling and shaft. It shows just how much force may be transmitted by the key under load so you can see how important a tight fit really is.
    It might seem like a real pain to disconnect the coupling but it shouldn't alter the alignment and it will give you a lot more confidence in the connection as well as reduce the risk of more expensive damage down the coast a bit.
    Good luck and keep us posted.
  10. CSkipR
    CSkipR Member
    Marmot,
    My coupling has setscrews so I will check to see if it is loose. If not I will attempt to remove the coupling and replace the key. Thanks again for your advice.
    Skip
  11. Marmot
    That's a good sign, it or they might just be loose or were never tightened. If they are loose, remove them completely and put them back in with Loctite. It will not be much fun removing them next time but nothing a little heat won't solve.
    Or, use setscrews in tandem like prop nuts if you have the depth.
  12. Golmar
    Golmar Guest
    If you do any distance cruising or have not checked the alignment is a few years I recommended you check it. You can be out of alignment without noticeable vibration. Run the engine in gear and watch the shaft, if it blurs you have a problem. Poor alignment can cause many problems including oil leaks, shaft breakage, strut damage, bearing and drive failure…
    Check the shaft flange faces; they should be parallel at operating temperature to .00015”. If you have a flexible coupler alignment is still important as they are a dampener not a universal joint. Remove the flange from the shaft (this should be difficult) and inspect all matting surfaces, use a new key and make sure it fits very snug in both shaft and flange separately. Reassemble and align. Repeat for your other engine.
    Proper alignment is not as simple as it sounds so I recommend you have it serviced by a professional. Your boat is an expensive toy so take good care of it.
    Good luck
    Going boating with a known potential problem is no fun.
    Would you go flying with your friend if he told you “that’s a little lose but I don’t think it will fail today”?
  13. Marmot
    I think you have a decimal misplaced, that is equal to .003 mm and is about 25 times better than acceptable.
    For an out of alignment shaft to blur it would have to be really far out. When CSkipR pulls the bolts and shifts the shaft back he will know instantly if there is an alignment problem and can measure it before doing anything else.
  14. Golmar
    Golmar Guest
    Your correct, I meant .0015"
    I have seen long shafts blur at just .010 off at the coupler flange.
  15. Bamboo
    Bamboo Senior Member
    Palm Beach, FL
    The difference is determined by the size of the shaft- larger shafts mean larger acceptable differences. I could not tell exactly what the talk was about early in the thread when folks were referring to the key as the "keyway". The shafts' keyways ought to be the same but the length sticking out of the coupling is not a area of importance as long as the key cannot work it's way out. On a 45 Viking the coupling is held onto the shaft (2 1/2 inch) with three allen head grade 8 bolts that are wire tied to each other so as not to vibrate loose IIRC. The coupling ought to be secured to the shaft so that hydraulic portapower is needed to break it loose- if not, as Henning said, this is an issue.
