Click for Glendinning Click for Burger Click for JetForums Click for Mulder Click for Abeking
Kevlar, Water Absorption Reported
Discussion in 'Technical Discussion' started by brian eiland, Mar 1, 2015.
  1. brian eiland
    brian eiland Senior Member
    St Augustine, Fl and Thailand
    An interesting observation by some friends who recently hauled there 65 foot catamaran vessel and found significant water absorption by the Kevlar material utilized in some of the construction
    http://dominocatamaran.blogspot.com/2014/12/pause-in-papeete.html
    Resin type and application issues. Sadly, your friends had to deal with this is some remote yet beautiful port. Tuna & local beer sounds great after a day in the water, not under my hull on da hard.
    I remember a story where one mfg was caught thinging the resin to get the cloth saturated quickly instead of working it in as required. Yep, it fell apart later.
    Pre-peg has become the norm now and modern bagging/ovens has eliminated these issues.
  3. brian eiland
    This vessel was built by the owners and a local company down in Uruguay. They spent a lot of time to do it correctly, but I'm sure they did NOT have any prepeg.
  4. brian eiland
  5. Capt Ralph
    She is a beautiful ship indeed. I'm sorry they had problems in paradise.
  6. Bill106
    Bill106 Senior Member
    Beaufort NC
    The Aramid (Kevlar) fibers don't themselves absorb water but if they stretch inside the resin matrix they break free from the surrounding resin and significantly weaken the laminate. If there's a penetration the water can travel down these "tubes" causing further damage as seems to be described in Brian's post.
    IMHO there isn't near enough information in the link about the construction (or damage) to make such a blanket statement that Kevlar shouldn't be used in hull bottoms. This sort of problem has been known about for a long time and specific methods of mitigating or eliminating it have been employed successfully. Higher elongation resins (ie. Vinylester and epoxy) allow the matrix to stretch more with the fibers and "hybrid" weaves using E or S glass and now occasionally even carbon fibers also combine their different physical properties and help the resin matrix stay bonded to the individual fibers. I've been building boats with epoxy/Kevlar/hybrid cloth skins for nearly two decades now and have yet to see any failures like the article described. There have been several impacts reported with floating debris and groundings but no problems with moisture penetration in the surrounding areas.
    12 days of sanding bottom paint???? That in and of itself doesn't make any sense on a 65' boat.
  8. brian eiland
    Perhaps just the older gentleman and his wife doing the work on a tropical island,....and having to sand down thru multiple layers on TWO long hulls. Does sound like it could make sense.
  9. brian eiland
    Thanks Bill,
    That was just the kind of thoughtful/knowledgeable submissions I was hoping to gather on this subject when I opened this subject thread.
    I believe many folks (including myself) have just always thought of this kevlar material as 'magical', and without faults.
    The water migration possibilities sound like some of those potential problems encountered with the 'end-grain balsa cores' that were suppose to be infallible.
  10. Capt J
    I don't know, it's certainly not a job I would enjoy making 12 days out of.....You could sand it down with a DA and one guy in about 2 days......
  11. Bill106
    Beaufort NC
    As with any "newfangled" product, there always seem to be some teething pains Brian. I seem to recall some of the early all Kevlar hulls built by a very highly regarded boatbuilder had delamination issues that forensic analysis attributed to the pure Kevlar being to stretchy for the polyester resin and fibers were moving inside the laminate. The solution was a higher elongation resin and a hybrid weave with e-glass that improved the resin bond to the weave. As with anything it's a compromise, the Kevlar is "held" by the glass fibers well below the limits of it's full potential to stretch and mitigate penetration and the glass fibers will tear first but the hybrid laminates have almost twice the damage tolerance of plain e-glass so it can be justified. Many of the high end sport fish builders use or have used it on premium builds; Merritt, Hines Farley, American Custom, Spencer, Tribute and us.
    End grain balsa core on the other hand still makes me shake my head. It does have excellent compression strength but add any moisture and it's mush in short order. I can't count the number of extensive repairs we've done on failed balsa structures, decks, hulls, cabins, hardtops, you name it. In fact I have to boats in the shop now getting just such repairs. Before the advent of honeycomb and higher density foam cores I can understand why it was so popular but nowadays I just can't fathom it's use.
