Click for Abeking Click for Mulder Click for Westport Click for Furuno Click for Abeking
Kenmore washer
Discussion in 'Post Yacht' started by Barney Hauf, Aug 30, 2022.
  1. Barney Hauf
    Barney Hauf Member
    Pompano Beach
    Has anyone replaced the Kenmore washer on a 50’ post. Mine gave up the ghost and parts are unavailable. The current washer is 22” wide x 22” deep. My boat is a 2000. Thought I’d check before I spend a bunch of time researching. Thanks!!
  2. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Been a bit of discussion.
    Use the search button
  3. Barney Hauf
    Barney Hauf Member
    Pompano Beach
    Thanks...Tried that before I posted the question. Did not see anything specific about washer replacement on a 50 of similar vintage.
  4. MBevins
    Windsor On. Canada
  5. Barney Hauf
    Barney Hauf Member
    Pompano Beach
    Thanks …. I actually used to have a 43. Sold it in March. I installed a dryer in the cabinet above the toilet. Super easy install…. Plug and play. Unfortunately it shares no similarities to the 50 so still looking for someone with experience replacing their washer on a 50.
  6. Soulstice
    Soulstice Member
    Portsmouth, Ri
    Let me check. The one in my 50 was replaced about 5-6 years ago and I will see if the new unit is still available.
  7. Soulstice
    Soulstice Member
    Portsmouth, Ri
    My washing machine unit is the Kenmore 44722 though it does not look like it is still available.
  8. Barney Hauf
    Barney Hauf Member
    Pompano Beach
    You were lucky to get it before it was discontinued! I have been looking at the Magic Chef 2.0 Cubic foot unit. It has similar dimensions to the Kenmore (Which was 22" by 22") Just worried it may be a bit too tall. Can't find one locally to go look at so I may have to order it and hope I can make it work with some modifications.
  9. Barney Hauf
    Barney Hauf Member
    Pompano Beach
    To close the loop in hopes that this might help someone else one day...Ended up replacing with an RCA 2.0 washer. It is the same as the Magic Chef just branded differently according to the research I did. The unit was about 2 inches too tall to fit in the space and allow the top load lid to open properly. I modified the height by removing the manufacturers plastic base and fabricating a custom base using marine plywood laminated to the correct height and epoxy coated. Once that was ready, I fastened it to the bottom of the washer. The new lower base height did not allow the drum evacuation pump to be locally mounted under the washer as it was originally. So I plumbed an outlet through the custom base and into a space under the forward starboard stateroom bed.... Extended the electrical connection and remote mounted the pump. This also allows me the ability to clean out the pump filter which would have been impossible had the pump remained beneath the washer without disassembling the cabinet that houses the washer and sliding the unit out. We washed a couple loads while at our home dock just to ensure everything worked as it should... And we are good to go!
    Oh.... 1 last detail. I sent the styrofoam factory packing that stabilized the drum during shipping to a friend with a 3D printer. He is making me a part of the same dimensions out of ABS plastic to keep the drum from moving and getting damaged while the boat is underway.
    chesapeake46 likes this.
  10. Davidoc
    Davidoc Senior Member
    Winter:Delray Beach, Fl Summer: Bahamas
    Very nice job!
  11. PtJudeRI
    PtJudeRI Senior Member
    Pt. Judith, RI
    I know this is older, but just as an update, Avanti makes a unit that is a drop in replacement as well. Their 2.0 cu ft. washer is 22" and fits perfectly. Should be around $500 at the big orange box store...
  12. Barney Hauf
    Barney Hauf Member
    Pompano Beach
    The Avanti looks identical to the RCA and Magic Chef... Likely all the same units with different brand names. Still working great!
